Well.. first time winterization of an LT1. I have read tons of posts and modified Eastie's (JimN?) checklist and supply list to be specific to the LT1. I have chosen to drain the block, fill with antifreeze and dry block again as it seems a bit more fool proof for noobies and meets all concerns. I have also re-orderd the checklist a bit so you can go right down the list in order. So... have a look and let me know what you think.
Winterization of an LT1 - Checklist
This is a sticky topic.
Originally posted by jakethebt View PostWell.. first time winterization of an LT1. I have read tons of posts and modified Eastie's (JimN?) checklist and supply list to be specific to the LT1. I have chosen antifreeze vs dry block as it seems a bit more fool proof for noobies. I have also re-orderd them a bit so you can go right down the list in order. So... have a look and let me know what you think.sigpic...A bad day water skiing still beats a good day at work...1995 Pro Star 205....
Originally posted by jakethebt View PostI had a hard time just finding 20W50. Only brand I could find was valvoline. I was hoping for a choice or two. Maybe Mobil1. This was just this past spring. Maybe this fall I will find a better selection.1981 MasterCraft
19' Skier 351W PowerSlot
Long gone is the Trans AMwaiting for another
Originally posted by 1redTA View Posti would run good 10w30 on an LT1 the bearing clearances do not warrant 50W oil
Oil was about the last thing I figured we would be talking about after posting the winterization list... I guess you guys think the tasks, order, etc are ok?sigpic1996 Prostar 205 LT-1
Originally posted by jakethebt View PostEverything that I can find say 20w50.
Oil was about the last thing I figured we would be talking about after posting the winterization list... I guess you guys think the tasks, order, etc are ok?sigpic...A bad day water skiing still beats a good day at work...1995 Pro Star 205....
Jake, well done. It's now, that time of year and have yet to winterize my LT1 myself....just keep bringing it to the dealer. I do have an appointment in a few weeks to winterize, new impellar and change tranny for $500 so quite a bit. After reading your info, it doesn't look too hard.
Appreciate you doing/modifying a good procedure list.....it will definitely help!
RV antifreeze be OK?- Jeff
1994 205, LT1
Originally posted by Ski-me View PostJake, well done. It's now, that time of year and have yet to winterize my LT1 myself....just keep bringing it to the dealer. I do have an appointment in a few weeks to winterize, new impellar and change tranny for $500 so quite a bit. After reading your info, it doesn't look too hard.
I didn't see anything on those lists about removing the hull plug(s), putting them in a plastic bag and attaching them to the steering wheel or throttle. They can be put in a cup holder, but that allows for them being moved and mis-placed. If the boat somehow gets wet and the plug(s) aren't out, bad things happen.
RV anti-freeze is bad for the heads. This was hammered into our heads at MC training every time I went. It may not happen after one time, but it's not worth risking, IMO.
If no anti-freeze is used, remove the hoses on the engine at their lowest points and turn them so any water in them can drain out. Crank the engine to clear the raw water pump or loosen the cover plate, to allow any water that's above it to drain out.
At some point, the bearings and brakes on the trailer need to be serviced- at least check them, annually if the boat is trailered frequently.
