Winterization of an LT1 - Checklist
This is a sticky topic.
  • mikeg205
    replied
    Originally posted by 1redTA View Post
    the LT1 is a roller engine
    Cool - wasn't sure...was looking it up and found flat tapped on '94s - would still run VR1 Synthetic/Royal Purple
    Leave a comment:
  • 1redTA
    replied
    Originally posted by jakethebt View Post
    I had a hard time just finding 20W50. Only brand I could find was valvoline. I was hoping for a choice or two. Maybe Mobil1. This was just this past spring. Maybe this fall I will find a better selection.
    i would run good 10w30 on an LT1 the bearing clearances do not warrant 50W oil
    Leave a comment:
  • jakethebt
    replied
    Leave a comment:
  • 1redTA
    replied
    Originally posted by mikeg205 View Post
    I would recommend VR1 Synthetic 20w50 or Royal Purple HPS 20w50. 1996 I believe still a flat tappet engine.
    Leave a comment:
  • mikeg205
    replied
    Well.. first time winterization of an LT1. I have read tons of posts and modified Eastie's (JimN?) checklist and supply list to be specific to the LT1. I have chosen antifreeze vs dry block as it seems a bit more fool proof for noobies. I have also re-orderd them a bit so you can go right down the list in order. So... have a look and let me know what you think.
    Leave a comment:
  • jakethebt
    started a topic Winterization of an LT1 - Checklist
    Well.. first time winterization of an LT1. I have read tons of posts and modified Eastie's (JimN?) checklist and supply list to be specific to the LT1. I have chosen to drain the block, fill with antifreeze and dry block again as it seems a bit more fool proof for noobies and meets all concerns. I have also re-orderd the checklist a bit so you can go right down the list in order. So... have a look and let me know what you think.
    Last edited by jakethebt; 10-07-2017, 11:33 AM. Reason: Updated lists... Fall of 2016
