Originally posted by Sierra Tango II
View Post
Yes, look in the thermostat housings and see if you can find pieces of the impeller.
How long have you owned this boat? If it's new to you, buy two impellers WITH THE GASKETS and keep one on-board at all times, as a spare. The knock sensor is the plug for that side and the other has either a petcock, a plug or a T-fitting for a heater. Remove whatever is there and make sure the water rushes out, not at slow dribble. You also need to remove the plugs or disconnect the hoses on the rear of the exhaust manifolds, the oil cooler and at the lowest points of the pumps, then crank it over with the lanyard off.
