2003 197 TT - Winterizing Ballast Pump
  • 2003 197 TT - Winterizing Ballast Pump
    Hi friends,
    Looking for someone to tell me if I'm losing it. I have a 2003 197 TT with the ballast bag under the rear seat, and the empty/fill pump switch on the panel near the throttle. I SWEAR last year when I winterized and pumped RV antifreeze through it, it emptied out the two ports on the passenger side. This year it emptied out the one hole on the drivers side. Am I nuts? Did I just write it down wrong last year? Or is there something wrong with how this is working? Just want to make sure I'm not leaving water somewhere it shouldnt be for the cold WI winter. Thanks
