Ok guys I know this has been talked about 1000 times and ive read everything I can but I still have a few questions so hopefully someone can review this list and answer any questions.
Boat is a 2010 X15 with a MCX 350
1. Pour in fuel stabilizer and warm engine up
2. Change engine and tranny oil
3. Drain block on both sides
4. Drain exhausts
5. Drain/Blow out heater
6. Reconnect all plugs
7. Flush the boat with RV antifreeze
Question- Where do I pour the antifreeze in when doing this?
Question- I'm writing this post without looking at the boat, where is the T stat located so I can remove it to make sure its open when doing this?
8. Fog engine at same time as pouring in antifreeze
Question- Can I fog it through the intake or do I need to do it through the spark plug holes? I have seen both mentioned but not sure which applies to the 2010 MCX
9. Fill ballast tanks with a bit of antifreeze and run pumps to get it into the lines
10. Grease steering
11. Remove batteries from boat
I'm going to be shrink wrapping the boat and storing it in the back yard as I don't have access to a shop big enough to put the boat into. I noticed during the summer water likes to sit at the corner of all the cushions and the corner of the sun pad cushions as well. Is there any reason I shouldn't remove all the cushions and bring them into the house and just leave it open inside? In my eyes that would let the boat breath a lot better and not allow moisture to sit in as many places.
Also do people leave the drain plugs out of the boat of put them back in to prevent animals from getting on?
If anybody has any pictures of the process I would love to see them to make sure I don't miss anything.
4. Drain exhausts
10. Grease steering
