Anybody out there with an older MC who has added BoatBuckle retractable tie downs to their older MC trailer? I see they make an optional universal bracket kit. Curious to hear from those who may have done this and any insight is appreciated. The welded hook point on my trailer is angled so not sure if these would work correctly, even with the universal bracket. Also doesn't look like they provide any protection for potential contact of the strap on the transom. Thanks in advance.
Retrofit BoatBuckle retractable tie downs on older MC trailers?
Originally posted by lakedrum03 View PostBeen thinking about this. I think you would need to add a bracket to the outboard side of the trailer rail. Or bolt them to the side of the trailer rail. Either way it may look goofy which has held me back.
I only travel more than 500 yards twice a year so it’s not high on my priority list.
Originally posted by MooneyFWD View PostI literally just bought the Boat Buckles and the brackets yesterday. I'm going to have to play around with it for the best location. Suggestions welcome! 2001 X30.¡Viva 205V!
2003 X2 MCX
- Likes 1
Originally posted by brucemac View PostAnybody out there with an older MC who has added BoatBuckle retractable tie downs to their older MC trailer? I see they make an optional universal bracket kit. Curious to hear from those who may have done this and any insight is appreciated. The welded hook point on my trailer is angled so not sure if these would work correctly, even with the universal bracket. Also doesn't look like they provide any protection for potential contact of the strap on the transom. Thanks in advance.
- Likes 1
Guess I should have trusted some of the reviews I had read. The hardware that comes with these is pure garbage. Got one on just fine, but the other nut seized up even after threading by hand (galling?). Had to cut if off with a hacksaw. Sent the mfg a note to see if maybe they can address, but in the meantime, looks like I'll need to go source some better hardware.¡Viva 205V!
2003 X2 MCX
Originally posted by brucemac View PostGuess I should have trusted some of the reviews I had read. The hardware that comes with these is pure garbage. Got one on just fine, but the other nut seized up even after threading by hand (galling?). Had to cut if off with a hacksaw. Sent the mfg a note to see if maybe they can address, but in the meantime, looks like I'll need to go source some better hardware.2000 Prostar 205V
Originally posted by dpb185 View Post
Did you use anti-seize ? Stainless steel bolts and nuts are notorious for cold welding (galling).¡Viva 205V!
2003 X2 MCX
Originally posted by CantRepeat View Post
Charles,
What size hole did you start out with? I assume a 1/2 inch x 3 inch then just a round over bit. Looks really clean!
- Likes 1
Originally posted by Skyskiguy View PostWhen I added Boat Buckles to my ‘06 I simply popped out the brake light to access the inside of the frame to attach the nut/hardware on the inside.
¡Viva 205V!
2003 X2 MCX
- Likes 1
OMG, why didn't I think of that!? Genius. So I'm assuming you drilled pilot hole parallel to the center line of the lens on that adjacent light and just left of the weld on that angled square piece of the trailer? I think I'm going to ditch the universal bracket and go that route. Way cleaner. Thanks for the tip.
