This is the first time we took all these measurements so I hope they are correct. If you are familiar with ordering any of these parts, can you let me know if these numbers look correct? I'm hoping I can give this information to various online businesses and get the right parts.
We have a March 1994 Mastercraft Trailer that pulls our 205 Prostar.
We need to buy:
1) Axle
2) Leaf Springs
3) Brake Actuator
4) Shackle Bushings
Axle Measurements:
3500 lb Load Capacity (Basing this off of other threads on here - we couldn't read on trailer)
66 1/2" Spring to Spring (measured from center of bolt on top to center of bolt on other spring)
85 1/2" Hub face to hub face (includes a 1/4" lip on the hub face)
90" Spindle end to spindle end
2" x 3" (Width x Depth) of Axle
1 3/8" Spindle Diameter
3 3/4" Drop
Leaf Springs
(I was planning on buying the springs at Northern Tool per members suggestions)
27" with the weight of the boat on them
4 Leafs
Double Eye Spring
Brake Actuator
Existing: UFP P/N 34039
Not sure what to ask for on the plastic shackle bushings. Has anyone ordered these before?
Thanks, as always!
Shey
We need to buy:
1) Axle
2) Leaf Springs
3) Brake Actuator
4) Shackle Bushings
Axle Measurements:
3 3/4" Drop
Leaf Springs
4 Leafs
Double Eye Spring
Brake Actuator
Thanks, as always!
Shey
