The axle on my 99 single axle trailer is pretty non-standard as axles go. Not sure about your 1989 which is 10 years older.
You'll need to list some of the details so you can get a good referral. For example my 99 is:
- 5200 lb capacity
- Painted
- Rectangular 2" x 3"
- Leaf spring (not torsion)
- 4" drop
After this you'll need the axle face to face dimension which requires a measuring tape.
As replacement axles go my 99 is pretty much a unicorn. I can't find any off the shelf that matches is exactly. Dexter comes pretty close with a 5200lb 2 inch drop leaf spring. You can get a 3500 lb, no drop, leaf spring axle of nearly any type by comparison.
I think the recommendation of getting one custom made is a good idea. If you are in a pinch, you might be able to get someone to weld your current axle as a very temporary fix. You'll also need to specify if you just want the axle alone or do you want the axle, backing plates, bearings, brakes, u-bolts (required!!!!). Changing the leaf springs is not a bad idea while you're at it.
The cost of a new fully loaded axle with bearings, backing plates, and hydraulic disk brakes runs about $1K total. Maybe a bit less.
