Brake actuator
  • Brake actuator
    Hey all,
    I have an '83 Mastercraft with a V/M dual axle trailer and a shot brake actuator. Its an Atwood 85736. Everything I find on the interwebz says the 85736 and its replacement 85841 are discontinued. Is there anything else that will work??
    1983 Mastercraft SS Powerslot 351w
    Postup a pic
      Heres a few pics
        https://www.amazon.com/UFP-Complete-.../dp/B074KKCJ26
        See the link. There supposedly is a UFP actuator that fits into the Attwood mounting. I have not used it and cannot speak to how well it fits / works. UFP is the most common actuator on trailers through around 2010.
          Looks like old master cylinder. Check measurements and see .. as stated above.. the ufp products will fit.
          You might need a new tongue on trailer to use new actuators
            Yah, its old. Tongue on my trailer is welded. I'd love to find a replacement, which is proving to be difficult
              Yikes... this would be a step up.. but you would need a good welder to cut off what you have and add the right piece of tongue
                Did you figure this out? My old boat had an actuator like this... I liked it much better than the one shown above due to the reverse "pinning". You pull the pin from under tongue and use it to lockout brakes for backing up.
                Tie Down Engineering Brake Actuator Model 660
                https://www.tiedown.com/pdf/c1250.pd...vw8h698aoawKY7
                2002 Xstar
                Old boat: 1988 Tristar 190
                  maybe it goes without saying but... the one above has a physical reverse lockout via the locking cap (optional) and comes with a reverse solenoid to lock out braking when your truck reverse lights are on.
                    I cut my old tongue off the end of last summer and put a UFP-a60 tongue on. I also changed the brake lines and put new kodiak calipers on. Now my brakes are awesome. I also made it swing away for storing it in my garage.
                    I have the reverse lockout cap but also wired in a 5 pin connector for the reverse solenoid. Now I don't have to get out to back up.
                    I does help that i work at a weld shop. I was done in about an hour with the cutting and welding.
                      ^^Just do this, you'll never regret it ^^
                        That's the smart move if you can do it.
