I have an 06' X-30 with a 13.7x17 prop. It does not have enough low end torque. When I load it up with ballast and people it takes way too long to get up on plain. Any suggestions on what pitch and size prop would work better.
06' X-30 Prop
Originally posted by shayne View PostI have an 06' X-30 with a 13.7x17 prop. It does not have enough low end torque. When I load it up with ballast and people it takes way too long to get up on plain. Any suggestions on what pitch and size prop would work better.
'04 MariStar 230VRS/MCX
I just put the 14.75 X 15.5 XMP Edge from OJ on for the same reasons. It is perfect for our use. We just use the factory ballast and run 6-12 ppl on a regular basis. With full ballast I had to change how I pulled the riders up cuz I was pulling the rope out of their hands. My top end dropped about 6 mph but the low end is perfect .
They also have a 14.25 X 14.5 if you are going to slam it out more and need even more low end. Here is Eric's explanation to me of the two.
"... The more aggressive of the two options would be the 14.25 X 14.5. The 14.75 X 15.5 will provide less low end improvement than the 14.25 X 14.5, still much better than the stock 13.7 X 17, but will run a bit faster on top end and lower overall RPM than the 14.25 X 14.5. "06 X-30
Why yes I do love a rampy wake with a firm lip. Thanks for asking.
