I got a new prop from Eric at OJ props. I have never installed one before so. What do I need to know? Thanks
Installing a new prop?
Here is the procedure in an older owner's manual. To be honest, I have not checked the contact area between my prop hub and the shaft (didn't know about this until after I had been running the current prop for a few years). But I know others who do. May tackle it as a small winter project.Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Originally posted by RMUDBUGS View PostI got a new prop from Eric at OJ props. I have never installed one before so. What do I need to know? Thanks
Tight fit between rudder and the shaft so it will take some maneuvering but you'll find that angle where the prop will come right out.
Slide on new prop, tighten nut firmly, and replace with a new STAINLESS steel cotter pin.Previous - 2007 X-Star w/ 8.1l
Previous - 2007 X2 w/ MCX
You'll likely want a puller to facilitate getting the prop off.
Inboard Propeller installation procedureInboard propeller installation procedure
Push propeller snugly onto shaft taper WITHOUT key in either keyway (propeller or shaft)
Make sure the propeller is snug and there is no side to side movement by gently moving propeller back and forth.
Make a line on the shaft with a non-graphite marker at the forward end of the propeller where it stops up against the shaft taper.
Remove propeller.
Put key into keyway on shaft taper with radiused or chamfered corners (down) in shaft keyway (if propeller shaft keyway has radiused corners).
Put propeller onto shaft taper.
Check to see that the propeller moves back to the forward line made in Step 3. If it does, skip down to Step 8. If not, perform the following:
A: Remove propeller from shaft.
B: Place a file on a flat surface area or work bench.
C: Run opposite end of chamfered key back and forth over file (to remove any burs) with a downward pressure on key until side being filed is clean.
D: Install cleaned key in shaft keyway with chamfered corner side down in shaft (the cleaned, filed side up in keyway).
E: Replace the propeller on the shaft and fit snugly on taper. Check to see if it reaches the line make as in Step 7. If it does not line up than repeat "Steps a. through e".
NOTE: A vice can be used to hold key and then filed, but care must be taken not to tighten too much, causing burrs and irregularities on key.
8. When propeller hub moves to correct position, install propeller nut on shaft and torque to seat the propeller. Install the torque jam nut also, if your shaft is so equipped. Install cotter pin at end of the shaft.
Correct Nut Instaltation Procedure: Install Jam Nut (thin) first than the Full nut (thick) goes on second.'04 MariStar 230VRS/MCX
'91 is tapered w/ keyway.
For stuck props, you can try WD40 or similar, but it's a tight fit, so won't help much.
Heat prop as a last resort, b/c Nibral is relatively soft material, but some hating of the prop with a propane or Mapp gas torch should make it expand a bit at pretty low temp. Heat evenly.
Or, after the prop puller is tensioned (nut still partially on the shaft so the prop doesn't come flying off), rap the end of the prop puller with a hammer. The vibration/impact will likely break it loose. Not too hard, the other end is connected to the transmission.
Last resort and I've never tired it, but sounds plausible if you're close to the water. Loosen nut a couple turns. Put boat in the water and nail the throttle a few times in reverse. The thrust of the prop will try to pull it off the shaft. Note if it's tapered, this could shear the key or ding up the keyway on the prop, I'd check it after each hit of the throttle myself.'06 X2 MCX
Originally posted by jbkriss View PostI tried to get mine off the other day (keyed) with a prop puller and it still wouldn't budge. I'll try heat like mentioned above. Any other pointers? Thanks.Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Originally posted by east tx skier View PostI had my puller torqued down so tight I couldn't get it tighter even with a 14" pipe wrench. 4 minutes with the heat gun on the hub and that prop popped off ... loudly. Make sure the nut is still on there.The Only Thing That You Can Give and Still Keep Is Your Word
