Bolts in my tracking fins 1982 S&S
  • Bolts in my tracking fins 1982 S&S
    A 1982 Stars and Stripes with the factory Powerslot transmission upgrade found me Labor Day Weekend last year. Since it was a 3rd owner boat with 496 hours on it and always garage kept I had to buy her. Well we have put 100 hours on teaching my 4 kids to do all the board sports (I tell them it won't pull a tube!) We have my 6-year old skiing, wakeboarding, and kneeboarding.
    Enough side-story. This past weekend while underneath her with the polishing pad I noticed that all 3 tracking skegs have a single bolt horizontally through the center from port side to starboard. Each bolt is a 1/4"-20 about an inch long with a big washer on each side and a lockwasher/nut holding it on. I went back and looked at the original manual which doesn't show bolts. Anyone seen this before? Is it common? Is it a handling modification?
    Salt boat by chance?
    Aric
    LONE STAR MASTERBASH 2022
    Register Here
    2019 XT22 - Ear Bleeder
    2022 Sea Hunt BX22 CC
    For Sale:
    2020 Crest 240 SLC Tri Toon
      That's what I thought at first; sacrificial anodes...It came from north Louisiana. There are no signs of salt water usage, no corrosion or anything like that.
        ...And they look to be standard hardware, not stainless or zinc.
          Never seen that before.
          sigpic
            Anyone else? The fins are original equipment from the factory; have "MasterCraft" cast in the base and everything. I don't see any evidence of there ever being a sacrificial zinc anode mounted to the fin, no scratches or un-even wear...
            I think I'm just gonna take the bolts out and see what happens. I may gain an MPH on the top end due to the decreased drag.
              I would take them out. I can't imagine what they would be there for.
              sigpic
                If the boat was from Louisiana........there is NO telling.
                May have been the attachments for gator trolling ?
                  It was "close-to-Texas-Louisiana"... Shreveport/Bossier City area; but granted, Louisiana none the less.
                    It would make sense that zincs were there if it was ever to go in the briny water. Perhaps the previous owner thought that theos bolts were better than open holes.
                    sigpic
                      Could be...
                      I'm going to run it once with the empty holes just to see, then probably fill the holes with JB Weld.
                        That's probably what I would do.
                        sigpic
                          Take 'em out and fuhgeddaboudit, the holes are too small to make a performance difference. It's not worth the trouble to use JB Weld; that would take another hour you can't get back. You are the only one that will ever know they are there. Admit it: even you didn't notice them until you were on your back inspecting the keel!
                            93 190
                            (safe click)
                              It's funny - you day epoxy and everyone is all smiles. Say JB Weld and people run away yelling and screaming.
                              That said, I have never used JB Weld because I always have some epoxy around.
                              sigpic
