92 prostar 190 powerslot
So I replaced the cutlass bearings and all seemed to go well. the original ones were very perished (See pictures) anyway like i said the new ones went in like they should however when i put the driveshaft through it doesn't even come close to alignment with the hole through the boat. What do i do to resolve this? all I can think of is pull the strut off and check it to make sure it is not bent. I can take it to a friends shop with a cmm so i can be pretty accurate there. but if it is not bent do basically remove it from the boat, clean the boat up and realign it so it goes in correctly then do a motor alignment at that point so all is square?
thanks
thanks
