Originally posted by BAdair
View Post
boat rudder port questions
AROUND EVERYTHING, IN EACH OF THE BOLT HOLES. You don't want to do it again. Had my son put his finger over the bolt holes so the goop would not get pushed out topside. You can coat the raw surfaces of the ports thru-hull hole a day before to seal up the materials there. From my experience, silicone does not stick to silicone.
Originally posted by Krw1225 View PostDid you send the rudder port in to OJ? Eric wouldn’t sell me the rudder bushing and seals without sending to them. I shot my port with more grease and seems to have helped as a stop-gap until the fall...
The removal wasn't that bad, had I just used the hair dryer from the start.
Sent from my moto z3 using Tapatalk
Originally posted by BAdair View PostI did. For $75 it's hard to beat. During my initial frustration I looked at replacing just the bushing but the price I saw online was over $100 for just the part so I didn't even consider it.
When reassembling, if you pre-grease the sleeve before you put the rudder in it will same you some time and clean-up. I did not do this step and when I went to pump the assembly full of grease, there was a lot of leaking around the grease zerk. I had to go very slow and do a lot of rudder turning in the process. Kind of a pain when doing it as a 1-man job.
The zerk on my assembly would not tighten completely so you might want to check that before installing also. We need our boat this weekend so I didn't have the luxury of further diagnosis. It had to go in so the adhesive could cure in time.
Overall, this is not a project that anyone with mild handyman skills should be afraid of. Just take your time and think through each step.
Old post but maybe someone knows. I am sending my port into OJs (still $75 btw) - does the outside plate even need to come off for any of this or can I just remove the rudder and take out the port box and then just reinstall inside when it comes back without messing with the outer plate?
Originally posted by Mwcoast View PostOld post but maybe someone knows. I am sending my port into OJs (still $75 btw) - does the outside plate even need to come off for any of this or can I just remove the rudder and take out the port box and then just reinstall inside when it comes back without messing with the outer plate?
