Bent strut, prop shaft and prop
  • Bent strut, prop shaft and prop
    Update: I decided to fix this myself. The pictures and write up start on post #13
    Just curious on some opinions. On July 5th I hit something at 8mph pulling a kid on a kneeboard. Long story short, my boat is broken. It is a 2004 Maristar 210.
    I dropped it off at a Mastercraft dealer on July 6th and they told me it would be done on July 17th. For that timeframe, I decided it would be worthwhile to file an insurance claim and just get it done in 2 weeks instead of doing it myself. I also asked them about adding ballast pickups while they were glueing on the underside of the boat.
    I called every few days because I didn't get a quote yet. Finally on July 14th they said they haven't gotten pricing yet and can't recommend a prop yet because no one is getting back to them. They claim they talked to Mastercraft and they said you cannot add thru hull fittings on this boat. I told them to ignore the prop and ballast pickups.
    I emailed Eric at OJ props on 7/16 back and forth and he had a prop recomendation and pricing we could agree on within a few hours. They had the prop on my door on 7/20 with a shirt in the box. Couldn't be happier or recommend Eric more!!
    Back to the dealer. On 7/27 I finally got a formal quote and they told me it would be 10-15 days before the parts would be in. There is apparenty also fiberglass damage that will have to be repaired.
    I guess my question after venting........Would Mastercraft say you can't add Ballast pickups??
    toddvdh
    I can't answer the question but ohhhhh shiiiiiitt. That's a wallhanger!!
      Ya. Eric said not repairable. Lol.
      We swam back in the bubbles behind the boat because it’s a known 15’ channel that I’ve been driving almost every weekend in summer for 5 years, and there was nothing there. I was hoping to find a giant snapping turtle or something cool.
        Dealer prolly does not want likability of drilling thru ur hull.
        Had to be a rock or tree trunk... thats a lot of damage.
        Too bad dealer so damn slow..
          Well, I picked the boat up unfixed yesterday. They finally ordered parts on Tuesday and on Wednesday when I called to get a date the parts are back ordered at least 3 weeks. They wouldn’t go to anyone but their usual supplier so I told them I’m not paying anything and taking my boat. I guess I learned my lesson and will never be going to them again.
          I contacted waterskis.com and they have all my parts in stock. They are shipping them and I’ll have them Saturday. Also ordered a flex gland seal from OJ props that will be here Monday.
          Both Midwest Water Sports/waterski.com and OJ have been phenomenal to work with and answered all my questions.
          There are some great write ups on how to replace strut, shaft and align them on this site. I’m going to tackle this myself next week. Thanks to everyone (especially waterlogged) who gives great advice in some of the other repair threads.
          toddvdh
            Both Midwest Motorsport/waterski.com and OJ have been phenomenal to work with and answered all my questions.
            You're mostly there now with the willingness to do the work.
            Post up if I or anyone else here can throw you a bone.
            Call if you like.
            93 190
              The hardest part is removing strut... ratchet strap heat and patience.. if you get frustrated or tired stop.. you will be amazed how easy but timely the job is.
              Dont forget the adhesive for the strut plate.
              Good luck. And post lots of pics please
                It only took me 40 minutes To get the strut off including unbolting it. So I’m at least started.
                I have 5200 coming with the strut but might substitute something easier to work with as suggested in other threads. The cutlass bearing is already in the strut I ordered.
                I am pretty mechanical so not too worried, just disappointed that I didn’t tackle it myself 3 1/2 weeks ago. I’m up at the cabin tonight until Monday so I’m pretty excited to come home Sunday night and start working.
                Thanks guys. I’ll be sure to take pictures and make a thread when I start it to help others out later on. Also in case I need to ask questions. Lol
                  Oh…NO
                  You only need the 4200…don't put the 5200 on! Period, you might find that snapping turtle again and the 5200 is not coming off…
                  second just smear with a plastic blade, the 3M 4200 thin, no thicker than a credit card evenly across the strut mounting face…THIS HELPS with the getting the original engine alignment back.
                    I'm just going to use the Star Brite Marine Silicone as it's available locally.
                      Any box store brand 100% silicone will work.
                      93 190
                        Well, so far it is going pretty good. On Sunday I got the shaft loosened and the strut area and holes cleaned up.
                        Old strut was pretty messed up
                        Also loosened up the prop shaft seal
                        Then I got the coupler nut off and the surrounding nuts. It actually went pretty easy except for a couple scrapes and banged elbows. I used a pry bar to hold the coupler and put a 2' piece of pipe on the adjustable wrench to break it loose.
                        toddvdh
                          On Monday I made a puller at work. Then when I got home Monday evening I had to cut 1/3 of it off to fit. I could only get two 5/16 x 3" bolts on it, and couldn't use the center bolt, but I alternated tightening them and after a little bit the shaft popped off. When I say popped off, it makes a pretty loud pop when it lets go.
                          Then I put in the new seal from OJ props.
                          After that on I got the new shaft slid in and 100% siliconed on the strut making a "gasket" and filling the bolt holes. I also slipped the prop on but haven't tighted it yet.
                          toddvdh
                            Great job so far! Hows the shaft look now that you've got it out?
