Depth & Water temp showing nothing
  • Depth & Water temp showing nothing
    2016 X46 - replaced the Triducer and still nothing appearing on the screen for Depth and Water Temp
    The paddlewheel circuit button under the dash appears loose and tripped and doesn't want to reset.
    Any thoughts?
    The triducer needs power, if the cable going back to the triducer got pinched or partically rubbed through you could have a short in the cable. I would try to trace that wire all the way from the triducer to the module.
      Ok good tip I'll trace it back the best I can
        You could also unplug the transducer from the computer and see if the fuse still blows.
          at the front of the boat behind the steering panel?
