Soooo..... I feel like an idiot with these questions, I have a 2001 Mastercraft pro star and I wanted to run my sound system off a deep cycle battery. I bought a switch for the battery that has 1,2 and 1&2, and off.
I went to take the wires off the battery today and noticed that there are two sets of wires leaving the battery. I ohmed the red wire (smaller conncetor wire) that goes to the 40 amp fuse in the picture and found that it went to under the dash to the breaker button pannel. Im honestly not sure where the solid red wire with the large lugs goes. My guess was this is just for the battery starter controlled by a relay?
my question is, would I be able to run the battery wires with the big clamp lugs to the the starter battery and the other two wires ( the ones that go though the 40amp fuse) to the deep cycle battery and not worry about even installing a battery switch?
Also im prepairng for the MDC delete on the MDC 1600 and the wiring looks the same as the guide except I have 2 brown wires on the output harness (Gauge harness as named in the guide) I don't see the guide mention these brown wires and im not sure what they are for or what do do with them. I do have a clock so im not sure if its for clock adjust? im really just guessing at this point.
