any experience pouring concrete boat ramp?
  • any experience pouring concrete boat ramp?
    With the lack of rain, the Mississippi is pretty low right now. Our club boat ramp is about 4 feet out of the water right now. When the water gets low, we usually have a load of rock dumped in and then leveled out to get us by. Every spring, the ice goes out and water comes up, and we lose our rock. Since the water is near record low, we're talking about extending the ramp down into the water.
    The plan is to build up a coffer dam, pump the water out, excavate, form, pour, let set up, and then remove the dam. We were thinking 6" thick concrete with rebar should work. We would drill into the existing ramp and tie in with the rebar. We weren't going to go too far into the water, maybe 2-3' deep, and our plan now is to use plywood for the dam walls. I'm a little concerned about shoring that up enough to prevent a blow out.
    Does anyone have any experience? Is 6" thick enough? My X-2 is the biggest boat to use the ramp, the rest are ski boats. How long do we need to let the concrete set up before we can stop pumping the water? I'm sure there are different cement blends, so do we just rely on the company to recommend the best for our application?
    I think there's concrete that you can pour underwater, but not sure if that works for boat ramps or not. Also, not sure if the river current would be bad on that as well.
    Any other recommendations, suggestions, or tips to help the project run smooth?
    I have no experience with this but I know of a number of places using precast slabs. Don't know if that could work for your application, but it could remove a lot of the variables.
    sigpic
      In a previous life the addition of "eucon" or super plasticizer allowed us to pour caissons under water. Hopefully someone on here is a civil engineer, or foundation inspector/ concrete contractor that will chime in. I have been involved with the addition/renovation of the old Portage Lakes state park boat ramps. That was driven sheeting but ODNR was footing the bill.
      https://badges.fuelly.com/images/smallsig-us/302328.png
      1988 prostar 190 SOLD
      2001 Prostar 209 SOLD
        Preform a slab with visqueen (sp) then tie it into existing ramp somehow at 3-4 attachment areas
        You will need something to lift or push it in
        Concrete does harden in water...pain in the but and the finish is not very good afterwords
        [email protected]
        www.BAYAREAWATERSPORTS.com
        (813) 996-BAWS (2297)
          You could pour on land and then push it into the water (after it sets) with a dozer if you have access to one.
          2002 X Star
          Sold - 76 S&S
            Yeah, I would guess that most launches (like ours here) use precast panel slabs (saw tooth top profile) that are laid in place. some are connected together by chains. You would need a loader/small crane to position them. Each slab may weight 1/2 a ton.
            Current: 2009 X-Star, Indmar 6L, 400hp, ZFT3 tower. c/w 1/9 scale R/C PWT X-Star
            Owned:
            2012 X25
            2011 X25
            2009 Moomba LSV
            2009 Moomba Outback V
            2008 Monterey FS180
            Pelican 4 set paddle boat
            plastic tug boat when I was 4
              Check out a place that makes pre-cast concrete catch basins. They may have a top to a grease trap or septic that can be used. They aren't that expensive. They can make almost anything. And they will deliver and place it if there is access.
                We did exactly as you stated for our local boat ramp when our lake was getting low, we just pushed the soil out with our backhoe loader into a dam wall. It leaked a fair bit and we had to have a pump going every few hours to keep it dry. 6" is plenty thick enough for concrete with mesh for reo. Plan B, assuming your current slab is smooth and level, could be to lay down some plastic and pour a slab on top of the one you have then use a bobcat or loader to push it in after a week. You will need to drill into the old slab and chain to the new one. You could also pour this slab elsewhere and bring on site but depending on the size this may be difficult. Plan C is to use or if not available pour concrete sleepers with reo and chain links put in them so you can join them together. Just add as needed. I would recommend this as being the simplest, but depending on how level your soil is at the end of your existing ramp you may need to level it first, but you will have to do that regardless. Have fun
                  Good info... The only other detail I would investigate is what to do with the subgrade. You should check to see if the subgrade is stable enough to lay the slabs on top - or will they slowly disapear under the lake bed. The shore line is dynamic, so Im not sure what kind of subgrade prep would be required... lots of granular? compaction?? to maintain a flat slope that will not undermine the concrete.
                  Owned:
                  2012 X25
                  2011 X25
                  2009 Moomba LSV
                  2008 Monterey FS180
                    bcd,
                    whatever you do...... video tape it and throw it up on youtube
                    there's not a lot out there
                    WE LIVE IN THE LAND OF THE FREE, BECAUSE OF THE BRAVE
                    Team MasterCraft Google Search Engine
                      I agree on the sub-base. I would suspect you need at least 12" or maybe more of some crushed rock as a base. Compaction would be good and at least use a plate compactor. If you can do it in a few layers that would make it better.....aka 6" layer, compact, 6" layer.
                      I've only seen big bridge construction in waterways so the method is probably over the top. We used big, steel plates that had ribs that locked together. You could basically drive them into the ground out in the middle of the water area and then put a pump in there to drain the water. As the water was dispersed out of the center, the outside water created more pressure against the steel plates....thus locking them together better. This was for large bridge foundation footings though so pretty "over the top".
                      I do remember using some special concrete that would cure underwater.....but you can't really put a finish on it. Pretty much big clumps that filled voids in the footings.
                      Anyways, just a little more info from my "early days" of civil construction in Seattle.....
                      Strictly going by his title....wouldn't this question be for "Tideengineer"?!? (I have no idea what he does)!
                      - Jeff
                      1994 205, LT1
                        Helped make one by framing it out with 2x6's in the late 80's. Poured it right in without displacing the water. Dragged a long 4x4 over to level it. As has been said, a bit rough, but was there about 5 years ago and it was still in use.
                          How is this "off topic"?
                            I'm a civil engineer. We built our slab on land and pushed it in place with a back hoe.
                              OK gang...reviving this. Private lake with no boat launch. Level sandy beach front. In a pretty remote area so really looking at DIY launch to launch my PS197.
                              I am poking around the internet and am seeing anything from pavers to timbers to pouring concrete under water. Thinking the best would be to form and pour on shore. Possibly 2ft wide by 4 or 6 or 8ft long sections and just rolling in.
                              Very little water level change and don't want to draw attention with coffer dam
                              thoughts?
                              2004 Prostar 197, ACME 843
