TeamTalk
TeamTalk (http://teamtalk.mastercraft.com/index.php)
-   Trailers (http://teamtalk.mastercraft.com/forumdisplay.php?f=27)
-   -   trailer LED lighting upgrade (http://teamtalk.mastercraft.com/showthread.php?t=107815)
ValveCoverGasket 04-27-2021 03:11 PM
figured someone might find this useful in the future, save a few minutes searching
but one of my winter projects this year was updating the dim original lighting in our 2004 tandem - i assume a lot of this is similar across many of the older trailers, but figured id put everything in one spot for posterity.
either that or im really bad at searching so it took me too long to find replacements i could guarantee would drop in without any other changes to the trailer :D
etrailer had everything, and id probably recommend getting new gaskets for the larger lights as the old ones were a bit loose on the LED housings.
no issues reusing the gaskets for the smaller lights
total cost - with the covid markup on the red model 60s - came out to around $250.
everything was standard truck lite lighting originally, and all the new LED stuff plugged in as a direct swap without any harness changes
excuse the rough sketch, but might give a little more context
top is a profile
bottom is the rear view
https://i.ibb.co/zhnwx2v/trailer-light-layout.jpg
total number of lights to replace on the tandem trailer was:
2x amber round model 10s on the front
2x amber model 15s on the front of the fenders
7x red model 15s, including the 3 on the light bar underneath the boat
2x white model 60s for reverse
2x red model 60s for tail lights
and the LED replacements for each:
round amber model 10 p/n MCL59AB
amber model 15 p/n AL91AB
red model 15 p/n AL91RB
white model 60 reverse light p/n BUL002CB
red model 60 tail light p/n STL70RB
model 15 grommets - i didnt order any of these and didnt find i needed them
model 60 grommets - i ordered 4 of these thinking itd be nice to have them, and ended up using all of them, so id recommend this
no finished night time pics, but its obviously a huge upgrade.... took less than a half hour to swap all of them. so this is definitely a quick project!
i got tired of pulling beat up uhaul trailers that had nicer lighting than our boat :D
waterlogged882 04-27-2021 03:29 PM
top is a profile
Deleted the spam link.
Thanks. I have a friend that I will pass this on to.
ValveCoverGasket 04-27-2021 04:25 PM
ah, missed that spam... that pic hosting got me with the copy/paste :)
prostar205 04-27-2021 06:19 PM
Bookmarking for next winter or possibly fall project. Need also to replace my carpet on the bunks. Going with GatorBak for that job.
mikeg205 04-27-2021 09:11 PM
Adding a set of white reverse lights would be fun.. motivated now for a rainy weekend project
ValveCoverGasket 04-28-2021 11:07 AM
im not even sure if it was factory like this, but the reverse lights i had were burned out.
itll be nice to back into the dark abyss at our storage without relying only on the truck lights...
chrisr 04-29-2021 02:54 PM
Thank you for posting this, I've got a 2006 un"reliable" trailer that is getting some much needed work. This helps a lot.
ValveCoverGasket 04-29-2021 03:27 PM
glad its of help!
if you havent already replaced your actuator and calipers, theres a couple threads on here with that as well.
wakeboy1 06-16-2021 12:41 AM
This is great, thank you. Our 2005 tandem trailer received a complete UFP actuator overhaul last summer and adding new LED lights was next on the list.
Tsumi 06-16-2021 02:02 AM
Some cheap Amazon LED light bars tied into the reverse circuit would be a good way to light up the garage.
2020
