TeamTalk
TeamTalk (http://teamtalk.mastercraft.com/index.php)
-   Restorations and Refurbishments (http://teamtalk.mastercraft.com/forumdisplay.php?f=62)
-   -   1994 Protour 190 Restoration (http://teamtalk.mastercraft.com/showthread.php?t=108044)
RDahler 05-24-2021 05:22 PM
3 Attachment(s)
Here are some photos of the progress. The plan is to make it better than new.
RxMC 05-24-2021 06:26 PM
Great plan! Looks like Powerslot too?
RDahler 05-25-2021 12:58 AM
This boat is the real deal a Bud water Ski Tour boat it was manufactured at the Maryville Tn, plant in June 93. The boat has the original LT1 engine, power slot transmission and prop. It never had a radio or speakers installed in it. Not shown in the photo It also came with the original T top. I am about 6 months into the Restoration and have taken a lot of photos.
RDahler 05-25-2021 10:50 AM
2 Attachment(s)
I started by taking the big T Helm apart and cleaning the old dried out Grease. Found the large plastic bushing had worked it's way up the shaft out of the housing just a press fit. This put a lot of play in the steering system. I staked the housing in four places above the bushing during reassembly problem solved. I used Mercury 2-4-c grease to repack the housing.
Had to install a screw on adapter for the new steering cable as the old screw on type in NLA.
RDahler 05-25-2021 03:01 PM
3 Attachment(s)
Next I removed the windshield from the boat and carefully the frames from the glass.
The original black paint was striped from the frames. I had the Aluminum frames Black Anodized and reassembled to the glass.
Torstenlaw 05-25-2021 03:19 PM
Looks great. Could you come and do my windshield! :-)
bret 05-25-2021 06:54 PM
He's just getting started with the pictures and the stunning work he's already done; simply amazing stuff!
Mark rsa2au 05-25-2021 07:09 PM
WOW, looking good! going to follow this with interest!
River Monsters 05-26-2021 10:24 AM
We have the same boat, just with the larger TV decals. Very cool stuff. Thanks for sharing.
SwissCraft1291 05-26-2021 10:36 AM
WOOW! Looks amazing!
Can you tell me where you found the foam seal on the front bottom of the windshield?
I think you will replace them too. Mine have shrunk through the years, become brittle, and should be replaced and I haven't found any suitable.
2020
