TeamTalk
TeamTalk (http://teamtalk.mastercraft.com/index.php)
-   General Discussion (http://teamtalk.mastercraft.com/forumdisplay.php?f=6)
-   -   The official X-30 Thread! (http://teamtalk.mastercraft.com/showthread.php?t=15418)
Skyskiguy 07-22-2021 12:58 PM
Originally Posted by Masterfoilcraft (Post 1578096)
Is the zerk in the hull or on the underside?
Zerk is on the rudder port in the bilge.
arcticsnoman 07-26-2021 04:58 PM
Okay, not sure what to do. Port side ballast did not empty last night when I hit empty all on the ballast screen. Screen said all tanks were empty, however the boat was lisping to port side. The manual override only operates the pump for 30 seconds (is this proper function) How do you empty the ballast then?
Skyskiguy 07-26-2021 09:32 PM
30 seconds is correct operation for the manual override. When you hit the manual override, is it actually emptying the tank? Is the pump running? How old are your pump impellers?
arcticsnoman 07-28-2021 03:00 PM
Yes, the pump is operating. Got half the bag emptied using manual override. Able to get boat on lift with out overloading the lift. Ran the override again on the lift once the boat was out of the water. Could hear water draining. Not sure as to when the impellers were replaced as I just got the boat.
2020
