TeamTalk
TeamTalk (http://teamtalk.mastercraft.com/index.php)
-   General Discussion (http://teamtalk.mastercraft.com/forumdisplay.php?f=6)
-   -   How to unclog shower lines (http://teamtalk.mastercraft.com/showthread.php?t=84373)
Boater_C 04-05-2018 03:54 PM
Hello!
I need some help how to unclog the shower lines of my 2000 210 Maristar. I thought the pump was weak (2 gal/min), so I bought a nice strong one (4.5 gal/min), but water still just basically dribbles out of the shower. Guessing I need to unclog the lines. Does anyone have directions for the best way of blowing out the lines? Note: I cannot access the hole in the bottom of the boat where water comes in because the trailer bunk is in the way.
Thank you very much!
kwoody51 04-05-2018 09:10 PM
Not speaking from boat shower experience but typically the head is the place that clogs. Pull this apart and see how it looks. I imagine it might have some scale/ flake that could be clogging it up.
wheelerd 04-05-2018 10:33 PM
When I first got my boat the shower was clogged. I just undid all the connections -- pump, shower head, cold/hot mixer -- and blew them out. I had a lot of sand in mine. There were a couple of small screens that were plugged up.
Also check for scale and debris in the outlet on the manifold or the block (whenever your hot comes from.)
Boater_C 04-06-2018 02:24 PM
I replaced the head, so that is not it.
Boater_C 04-06-2018 02:25 PM
Thank you! I will try to disconnect every line I can.
LittleFuss 04-06-2018 03:44 PM
What Wheelerd Said
