TeamTalk
TeamTalk (http://teamtalk.mastercraft.com/index.php)
-   Electrical (http://teamtalk.mastercraft.com/forumdisplay.php?f=23)
-   -   Not reaching set speed (http://teamtalk.mastercraft.com/showthread.php?t=99161)
dcwalkaw 09-16-2018 06:18 AM
I have a 2014 X25, and yesterday I was having problems reaching my set speed when my cruise was on. I could only reach 9.5 when the cruise was set at 10.6 in surf mode. In Go Home, it would reach 20 mph before losing power and going back to 0 mph (cruise set at 28). I finally figured out if I turned the cruise off then the boat ran fine. Anyone experience this, or might know what is going on?
MattsCraft 09-16-2018 07:53 AM
From your description, sounds like the GPS puck is bad. It is the black puck just outside the windshield on the drivers side - You can follow the wire from here under your dash & see where it plugs in, I would start by re-seating the plug to see if that helps, other than that, you'll probably need a new one from your dealer.
