Old 01-29-2018, 10:23 PM
Barefooter92's Avatar
Prop Puller
Seems to me a proper prop puller is about $90-100.
I only need it once. What are you all doing instead?
Does anyone rent them?
Old 01-29-2018, 10:27 PM
best luck
John 14:6
Old 01-29-2018, 11:07 PM
Bongo Bongo is offline
Boat: 2004 MasterCraft 197 TT
I've had my best luck using a short 2"x4" - say 8" long, a hammer and whacking it from the prop shaft toward the back of the boat. Using the wood deadens the hammer strike so it isn't such a sharp blow. Put the 2"x4" on the hub, not the blades. Line up the wood and hammer as close to parallel with the prop shaft as possible; don't want to bend the sucker. Whack. Rotate. Whack. Rotate. Whack. Rotate. Whack. Rotate. <Repeat a lot.> <Take a break.> <Come back the next day.> <Repeat a few more times.> ... And just when you think you've made absolutely no progress, the next whack springs it free. Ok, maybe a dozen later.
I've also used and have access to a prop puller. Still, I start with the 2"x4" and that has always worked.
Oh yeah, leave the nut on very loosely. So that when you whack it off, it still stops on the shaft. Don't want to (further?) damage the prop.
Bongo
Old 01-29-2018, 11:50 PM
required tool for shaft drive boat ownership - hopefully you don't have to use it...
another way to loosen prop - loosen prop nut a bit - put boat in water - put in reverse.. it just has to move about 1/32 or so to be loose enough to remove...
Old 01-29-2018, 11:56 PM
gweaver gweaver is offline
I did the 2x4 whack-turn-whack-turn routine twice. Third time, i decided a prop puller was a good investment. I've used it several times since. One time, the prop I was pulling wasn't even damaged.
I'm glad I spent the money on it.
G
Old 01-29-2018, 11:57 PM
ted shred ted shred is offline
Boat: Mastercraft,powerslot,1983,pleasurecraft 351
That's exactly how I have always done it. works great.
Old 01-30-2018, 12:03 AM
wheelerd's Avatar
wheelerd wheelerd is offline
Boat: 2005 X2
My puller is a standard part of my onboard toolbox. Never know when you need it out on the lake or at a remote beach to replace a prop that is dinged. (Also a pair of goggles for working underwater.)
2005 X2, Viper Red, MCX, OJ TZ-X5 prop, PPass, rear 750 sacs, KBS, IBS, Bennett Wake Plate
Old 01-30-2018, 02:07 AM
Thrall's Avatar
Thrall Thrall is online now
Boat: '06 X2 MCX
One of the things I don't have a hack for. I bought a puller. Otherwise, beat on it with a 2x4 like above. Helps if you heat the prop around the hub.
'06 X2 MCX
Old 01-30-2018, 02:46 AM
Fullpass's Avatar
Fullpass Fullpass is offline
Prop Puller is nice to have...kind of like an oil filter wrench, not used often, but need it.
Old 01-30-2018, 07:46 AM
Covi's Avatar
Covi Covi is offline
Boat: 2008, PS 197, LY6
I own and use a prop puller. Best 100$ you can spend. I’ve also used a 15$ large “C” clamp. Mimicking a prop puller. The 2X4 and hammer whack doesn’t seem right to me.
86' 19 Skier, 351 PCM (sold)
2008 197 ProStar, LY6
