New seablaze Quattro is what I am going with
Underwater Lights Wiring
2017 Mastercraft XT21- Black & Calypso Green Flake and Coolfeel interior
2018 Audi Q7 Technik Navarra Blue with S-Line, Black Optics, Luxury package, advanced driver assistance, Audi Sport 21" wheels, tow hitch
Are these lights all compatible with factory wiring? I haven't done much poking around in my boat, I have a 2009 X-55. I have three switches at the back, one for the shower, one for u/w lights and one for slick boot. looks like the switch bank I attached. Anyway, if I get some lights from Lumitec for example, should I be able to just wire them into that harness that goes to the U/W light switch?
Originally posted by Proedge View PostAre these lights all compatible with factory wiring? I haven't done much poking around in my boat, I have a 2009 X-55. I have three switches at the back, one for the shower, one for u/w lights and one for slick boot. looks like the switch bank I attached. Anyway, if I get some lights from Lumitec for example, should I be able to just wire them into that harness that goes to the U/W light switch?
If you want to plan for the future, look at YouTube for videos about Lumitec's Pico. It's pretty cool.
I was just thinking about ordering two of the Lumitec's SeaBlazeX Mini lights. They seem to be able to do the job without costing an arm and a leg. They are 670 lumens for the Spectrum model.
The wiring should be something like this, with a 5amp fuse. I'm guessing 5 amps should be enough for a couple LED lights..
Originally posted by Proedge View PostI was just thinking about ordering two of the Lumitec's SeaBlazeX Mini lights. They seem to be able to do the job without costing an arm and a leg. They are 670 lumens for the Spectrum model.
If you use the Mini lights, they're rated for 990mA, so the existing switch and wiring will work but if you want to use the Spectrum lights, it will need to be re-wired.
Originally posted by JimN View PostTheir website shows that each light is rated for 5A- that means you need heavier wire from the battery to the switch. Find the rating for the switch (it should be on the switch, usually on the side or back) and if you need a diagram for the heavier wire, fuse, etc, let me know.
Originally posted by JimN View PostShow me where I used ‘any’ in my comments.
The OP needed specifics, not a general negative answer. Why do you want to start a pissing contest?Originally posted by MLA View PostJeez dude, go back and read my post and WHO I QUOTED
talk about someone wanting to start a pissing contest.2020 Table Rock Mastercraft Reunion Poker Run Champion
I lead the fight to ban the swimsuit thread, help me bring it back: https://teamtalk.mastercraft.com/sho...58#post1494758
"LDA never saw a thread he couldn't run off the rails"
If you don't want to crack your gel coat then chamfer the gel coat at 45 degrees to a depth the screw threads wont screw into the gel coat but rather into the under laying fiberglass. If the threads of the screw don't bite the gel coat you have almost zero chance of cracking the gel coat. At this point the only thing that will cause a crack is you over tightening the screws.-Tim
