Hello,
I am new to Team Talk as I just purchased a 2010 X25. I am very impressed, it is a HUGE upgrade over my 2006 Centurion Air Warrior in so many ways.
However, I am having a hard time getting a decent surf wave on the right (Starboard side). My daughters and I are all goofy foot, so that is the side we surf on. The surf wave on the Port side is fantastic, so I don’t know why it is so different on the Starboard side.
I am using a Mission Delta wave shaper and weighting the boat evenly (both side and KGB are full), but when I put it on the Port side (to surf Starboard) it seems to be further out of the water than on the opposite side. I was considering putting more weight on that side, but it seems counterintuitive for surfing??
I tried the Gen 1 surf tabs, and they seem to be working, but I was wondering if maybe the port side tab is giving way under pressure?
Also, the ballasts only seem to fill when the boat is revving around 1500-2000 rpm, which means that once I select my setup from the list, which you can only do at idle, it will set my tabs, but I have to fill the ballast manually. Anyone else experience this or nor what the fix is?
Thank you,
Thank you,
