Old 01-23-2021, 11:33 AM
Soder's Avatar
Soder Soder is offline
Boat: 2004 X-30 MCX
FAE (Fresh Air Exhaust) Transom Spray
I installed my FAE last summer and have enjoyed being able to talk with my surfers.
The only issue I have discovered is that when the boat is going faster than surfing speed, I get a "peacock tail" spray coming up my transom between the transom and swim platform. The shape of the transom below the swim platform almost seems to funnel the water right up between the two.
I'm thinking of putting some sort of rubber hose or weather stripping between my transom and swim platform to block the spray. Before I got creative I wanted to check to see if any of you have had the same problem and what creative solutions you have.
2004 X-30 5.7L MCX
Old 01-23-2021, 11:38 AM
moosehead's Avatar
moosehead moosehead is offline
Boat: 20 X22 6.2L GDI, '15 X10 6.0L
Recognizing this doesn’t help you, but feels like if that downpipe were less vertical and angled aft a bit, might solve a bit of the spray?
Old 01-23-2021, 12:10 PM
wallnut21 wallnut21 is offline
Boat: 2019 MasterCraft X24
Put a seal/weather-stripping between platform and transom. New boats have this from factory as it was a common complaint will surfing.
Old 01-23-2021, 03:22 PM
Soder's Avatar
Boat: 2004 X-30 MCX
The downpipe angle on this version can't be changed. That's how it came directly from FAE. I'm assuming that's the way their expert engineers intend it for best performance.
Good to know newer boats fix it with a blockade of some sort. That makes me forward thinking, right?
3 ideas:
4' plastic pipe (1/2" or 3/4") and screwing it onto the platform
Garage door type rubber weather flap
D-profile weather stripping
2004 X-30 5.7L MCX
Old 01-23-2021, 08:24 PM
cwarndahl's Avatar
cwarndahl cwarndahl is offline
Boat: X-45 finally better then x-10
I have the same problem on my x45 Id like to see what you do. I wear
Going to reset my swim platform closer to the boat.
2012 MC X-25
Old 03-20-2021, 06:50 PM
Soder's Avatar
Boat: 2004 X-30 MCX
I decided to go the "garage door weatherstrip" direction. As you can see from the pictures, I grabbed some Garage Door Seal from Lowes that had about a one inch flap.
With some 1/16th inch x 1 inch aluminum and some SS fender washers, I through bolted the seal onto the front of my swim platform. If the fender washers rip through the door seal, I have enough leftover that I can flatten the fender washers on one side and redo the door seal.
The flap didn't extend as far as I wanted it to so I used some clamps/boards and with some gentle persuasion from a heat gun, I made sure the flap was reaching as close to the boat as possible. The heat also took out some ripple in the door seal due to the curvature of the swim platform.
The door seal touches the boat on the sides but in the middle where the transom has a different curve, the door seal is still about 1/2 inch from the transom. It's still two months before early boat season here, but if it's still a problem, I can still add another 1/4 inch of spacers to push the door seal even closer to the transom.
I welcome any suggestions to make this even more effective. The whole project took about 90 minutes.
2004 X-30 5.7L MCX
Old 05-25-2021, 03:53 PM
Cshaw's Avatar
Cshaw Cshaw is offline
Boat: Mastercraft, x45, 2007
Have you had any issues with performance? I ended up taking mine off of my x45. Between the spray and the performance issues it wasn't worth it. I do miss how much noise it reduced. I had problems with it affecting the wake when trying to wakeboard around 21mph. It would kick up a rooster tail. I have the peacock spray problem and surfing speed as well. I tried multiple garage door strips, pool noodles, etc. but nothing would ever stay in place despite 3M adhesive or gorilla glue. I like your idea of bolting it to the platform.
Old 05-31-2021, 03:16 PM
PS205Tex PS205Tex is online now
Boat: 2008 X14
This inverse Y design and the new spray guard really help. Its a vast improvement over my previous FAE.
2008 X14
1964 Boston Whaler Nauset
1994 PS205, sold
Old 06-01-2021, 10:48 AM
Soder's Avatar
Boat: 2004 X-30 MCX
I finally got to take the boat out last Friday. The weather stripping worked perfectly. No peacock or rooster at any speed.
I've never noticed any performance issues from my FAE. I was hoping it would make my boat silent...but that may be asking too much.
Happy summer, happy boating!!!
2004 X-30 5.7L MCX
Old 06-01-2021, 07:29 PM
Boat: 2008 X14
Great news! Have a great summer!
2008 X14
1994 PS205, sold
2020
