I have a 2008 X30 - had overheating issues before, putting the boat into limp mode. I was at least smart enough to watch the guy when he came over last time to see what he did about the issue. First was getting to the pre-tranny cooler - found seaweed. So, I tried that method first, got a lot out. Still overheating. I then replaced the impeller in the water pump - turns out the one I had in looked brand new but replaced it anyway. Still overheating. Had the guy come out this year and he then went to the next cooler after the pre-tranny - found A LOT of seaweed in that one. Took the boat out, temp up to 200 degrees fairly quickly but not as quickly as before removing the seaweed.
He then go back to the water pump and found that the bracket was broken, which he said is actually NOT very common. Suggestion now is to obviously get a new bracket and probably replace the water pump as with a broken bracket, it can cause the pump to vibrate etc. and affect the bearing (not sure what that is honestly), so I told him to do whatever he needs to do.
His main suggestion was to install a strainer under the middle seat area where there's quite a bit of room over the gas tank. Should solve the seaweed issue once and for all. Anyone else have of of these on their boat? I won't install it myself even though I believe it's fairly straightforward.
As a result of all this, no boat this Memorial Day weekend but at least the kid could tube from the Wave Runner!
