Intermittent crank, figured out that it is the ground cable on the battery. Was able to get good connection for testing.(he is ordering new cables). do you know the length he will needd for a positive an negative on an 89 prostar with the battery cable?
Now for the odd part, when i crank the boat will start. AS soon as i release from start it kills everything. Only time the fuel gauge works is when cranking, not when on the on position. Vollt meter never moved cranking or not.
I replaced the ignition with a brand new one(wired the same as old switch) and still the same. My thought is either the old ignition switch pulled a wire at the on position when i removed the old one and i never reconnected or I dont have a clue.
If I pulled an ignition switch wire what color would it be that should be on the "on" position andd not the "start" position?
sorry for the crap spelling, keyboard is going on my cpu
