  #41
Old 08-30-2016, 11:48 AM
ccope's Avatar
ccope ccope is offline
Boat: 2002 X30, 330HP LTR
I have replaced the black pigtail connection and still have the same intermittent issue where the engine cuts out. Jiggle the connection and it starts backup. Must be the the yellow component right?
Any idea where I can buy JUST the yellow piece?
2002 X30 330 LTR
Thanks!
Old 04-04-2017, 01:30 PM
this was a few posts above....
i think this would work
https://www.turbotweakstore.com/Prod...de=1037-walbro
Old 08-05-2018, 05:25 PM
FlyingFreeman FlyingFreeman is offline
Boat: 2002 Tournament Team PS-197 LQ9 #88
Stabilant 22 Electrical Contact Enhancer
You could try Stabilant 22. Available online, I think Napa may have it also.
http://www.stabilant.com/sizes.html
https://www.amazon.com/Stabilant-5ml.../dp/B001E50GQS
It's working for me so far.
If mine acts up again, I'm going to solder on a new metripack male to the fuel pump module connector (or use a Molex female and male instead of the metripack connectors).
I also eliminated the metripack quick connectors in the harness from the rear of the engine and near the fuel pump since I have had problems with those as well in the past. They are great for ease of assembly at the factory, but they have been a problem in many boats causing people to replace good fuel pumps thinking they were the problem.
It's not that the connectors are under rated or overloaded, they just seem to be an intermittent problem on a mission critical component, the fuel pump.
2002 X30 330 LTR
Thanks!
Old 05-26-2020, 01:26 AM
Wwnd Wwnd is offline
Boat: MC x45 2006
Found my harness melted.
Turned to the forum for assistance and found this thread. Would like to replace both sides of the harness (yellow and black). Links are no longer valid since the thread (and my boat) are so old.
Anyone have part numbers for the two parts?
Appreciate it!
Boat is a 06 x45 w 8.1L.
Old 06-28-2020, 09:50 AM
rspiecha's Avatar
rspiecha rspiecha is offline
Boat: 1994 Prostar 205/2005 Maristar 210 VRS - MCX
WWND, did you get any answers back on your question? I have a 2005 X10 with MCX that just did the same thing on the boat side connector.
Thanks
Rob
2005 MariStar 210VRS - MCX - ACME #845
1994 Prostar 205 TBI 350 (SOLD)
War Eagle
Old 06-28-2020, 10:48 AM
mtajpa's Avatar
mtajpa mtajpa is offline
You might try something like this and just replace the whole yellow connector.
https://www.summitracing.com/parts/abt-cfd-504
Be sure to read the comments section if you purchase.
99 MariStar 230 Sport LTR 330
Old 06-28-2020, 01:23 PM
Super Moderator
Those are weather pack connectors... there a very large selection of connectors..
Old 09-08-2020, 09:15 AM
DesertProstar DesertProstar is offline
Boat: 2001 Prostar 190
Does anyone have part numbers for this yellow connector/harness? And for that matter, a replacement pump for the in tank fuel pump module? Boat hasn't been started in 2.5 years. Engine cranks, but fuel pump won't prime at Key ON. Tracing electrical, I'm getting 12.67 volts when I put the multimeter on the hot and ground on the female side of this yellow connector after jumping the relays, and tried powering the pump directly as well, but still won't prime.
There is no continuity on the male end of this connector, so would seem to suggest that:
a) wiring issue somewhere from yellow connector to the pump; or
b) the fuel pump itself is shot.
I was going to order a new yellow harness and new pump/in tank filter and replace it all. I'm located in the middle east, so no reliable autozone/napa to be sure I'm getting the right parts. Way easier to order from stateside.
Thanks all.
Old 09-08-2020, 03:42 PM
prostar205's Avatar
Boat: 2002, X30, L-18
Following
Old 09-08-2020, 05:09 PM
Cougar694u Cougar694u is offline
Boat: 2009 X14 - Sold: 78 S&S
These are buried in the Fuel Pump 101 thread:
harness: https://www.racetronix.biz/k/fl98-f7...ly/bcwa-fl98hd
Yellow connector only: https://www.racetronix.biz/p/fs-bulk...y-4-way/bca-4w
2020
