Might be a dumb question, but can I use the engine flush hose connection to run water through the engine instead of using a fake a lake to run my engine out of water? My guess is no, but I'm not really sure.
Engine flush hose in place of fake a lake?
Does this flush location also work for running antifreeze through the engine?'18 XT22 w/5500 & Upgraded Premium Stereo
(Previous- '08 X2 w/MCX)
'16 F150 Platinum Screw 3.5L Eco 4x4
I can help with Klipsch Stereo modifications
www.chesnuttech.com
Originally posted by Tookeymonster View PostYes, that is exactly what it is for. Just make sure no one turns the water off and you have plenty of pressure.
I want to fill the gas tank and then add stabilizer as I'm pulling the boat out for the season, so I'll use this connector to run the engine to allow the stabilizer to work it's way through the system.
Thanks
Originally posted by yomotha View PostOh, interesting. Well, I bought a fake a lake not knowing I could use this connector instead. This is my first year with this boat so I'm still learning what's what.
Thanks
The flush connection is meant to run water through while the engine is running. Never just flush water through, it can fill up in the exhaust manifolds and get into the cylinders.
Without a flushing hookup, I simply remove the raw water hose from the hull valve and stuff a garden hose down it, turn water on full blast and start the boat immediately.'06 X2 MCX
So don't hook the hose up and let it run for long before starting the engine? I might have to put a valve on the hose to control both from within the boat. I don't really like the sound of water getting into parts of the engine it shouldn't. Makes the fake a lake sound safer, but I haven't done either method yet, so I don't really know much at this point.
I remove the raw water hose from the hull valve and put it in a 5 gal bucket, I put 2 garden hose in the bucket and let the engine pump what it needs. You can finish by shuting off the garden hoses and manually add plumbing antifreeze in the bucket. Shut off the engine when the bucket is emptied of antifreeze.
When my winterization was done they had a hose attachment with a valve between the garden hose from the sump pump and the flush connection. Filled the bucket with anti freeze and started the sump pump making sure the valve was closed. Jumped in boat, opened valve and immediately started motor. Sucked 6 gallons through, stopped motor, then closed valve. Very quick and easy.
Chris
Originally posted by Cyoder1 View PostWhen my winterization was done they had a hose attachment with a valve between the garden hose from the sump pump and the flush connection. Filled the bucket with anti freeze and started the sump pump making sure the valve was closed. Jumped in boat, opened valve and immediately started motor. Sucked 6 gallons through, stopped motor, then closed valve. Very quick and easy.
Chris
Sounds right. The dealer told me the sump pump wasn't necessary because the motor should suck the antifreeze out of the bucket just fine but they figure it can't hurt having the extra help of the pump.
I believe when doing the non-pressurized method you have to fill the sea strainer first and then fill the exhaust hoses? The sea strainer on the GDI motors looks like it would be difficult to fill due to the way it's mounted. Also, I haven't looked closely at the exhaust hoses but on my old X25 they used special clamps on those hoses that needed to be cut off and replaced with regular hot clamps. In the back of my mind I would wonder if regular hose clamps were sufficient why wouldn't Ilmor have used them in the first place.
I'm no expert on winterization by any stretch. I went to the dealer with the new boat so I knew how to do it going forward. Their method seemed pretty easy so I'll just do it the way they showed me.
Chris
Yes, forgot about the sea strainer. The hose clips look pretty standard to me on my engine; nothing special that I can see. Anyway, I used the engine flush connection to run the engine after adding the fuel stabilizer and it worked like a beauty. I just added a hose valve as well so that I could adjust the flow from within the boat as required.
Thanks
Originally posted by eecyclone View PostDoes this flush location also work for running antifreeze through the engine?
