Go Back   TeamTalk > General MasterCraft Topics > Tow Vehicles
Old 06-10-2019, 11:19 PM
dhanni848's Avatar
dhanni848 dhanni848 is offline
Boat: 1988 Mastercraft TriStar 220
Location: Southeast (Percy Priest, Dale Hollow, Center Hill)
2011 F-150 famous Blend Door help needed!
Any of you with a little bit older F-150 has probably experienced this issue so any help would be much appreciated!!!
So replaced my passenger side (upper) blend door actuator since I had the famous clicking/knocking, and mine actually was constant and never stopped. After I replaced it I still get a few clicks once I start the truck and then it stops. AC and heat work how it should and have both on both side with dual control. Any ideas of what else it could be causing these clicks now? I did the fuse pull calibration multiple times.
Also, the lower door does not click but I cannot switch from defrost and floor to front vents, it stays on vents. I removed the lower one and can manually push the door up and down. Assuming the lower needs replaced too!? Would this cause the upper to click at all?
Thanks in advance! About to lose my mind over this.
03 Super Air Nautique TE 210
88 Mastercraft TriStar 220 - Sold
