FYI max towing capacities are for sea level, flat land, and one 185 lb passenger in the vehicle and nothing else in the vehicle. Also if it comes with a hitch most hitches are rated for less than towing capacity, your only as strong as your weakest link. Also if you add one 200 lb person it actually subtracts more than 200 lbs of tow capacity, I cant remember the ratio (pay load is different than towing).
Also always check the ball mount that goes into the hitch most are under rated and when you flip them over like in Arks pick it reduces the load capacity. How, I don't know.
