Old 05-15-2014, 02:42 PM
Jeff d Jeff d is offline
Boat: 2000 230 VRS
So, if you want to buy a setup that can be filled with a portable pump now and then plumbed in later here's what I'd do.
If you're a big surfer then get this:
http://www.wakemakers.com/fly-high-j...t-package.html
If it's mostly for wakeboarding with a little bit of surfing get this and save $80:
http://www.wakemakers.com/fly-high-f...t-package.html
Then get this integrated bow sac:
http://www.wakemakers.com/fly-high-i...d-bow-sac.html
That will get you going but you certainly will not be able to fill either of those rear sacs full for wakeboarding. You'd be way too rear heavy. So, you'd probably just going to be limited to filling the rear 40-60% depending on if you can get a person or two to sit in the bow.
You will be able to fill that one side full plus the bow sac mostly or completely full for surfing. You'll have to play with how much to fill the front.
Get used to that for a while. If you want to go bigger then get this to put inside your ski locker:
http://www.wakemakers.com/fly-high-tube-sac.html
That weight towards the front will allow you to add more to the rear sacs for wakeboarding. You still will likely not be able to fill them completely. Also, at this point (Possibly even before this point) you'll need to start considering a new prop since your takeoff speed will start to suffer.
Then you'll need to buy this (OJ 722 14.75 X 15.5 LC 1 1/8" 4-blade):
http://www.wakemakers.com/oj-522-propeller.html
Also, at some point you may want something like this Fat Brick to be able to adjust for people weight or just to stick up in the nose of the boat when nobody wants to sit up there:
http://www.wakemakers.com/fly-high-fat-brick.html
Somewhere during that evolution you're probably going to decide you either need to plumb in this stuff or get another portable pump because you're spending 30+ minutes setting up and 30+ minutes breaking it down every time you take the boat out. It's not cheap to buy all of the pumps, hose, fittings, switches and wiring and takes a lot of time. It also takes a lot of balls to drill a bunch of holes in the bottom of the hull for intake and the sides of the hull for overflow/drain. I don't have a firm number documented on what it took me.
As you can see you can spend quite a bit of money here.
Old 05-15-2014, 02:45 PM
Boat: 2000 230 VRS
Also, if you're hard core and don't care if you have ballast taking up seating area then just buy this instead of the Integrated Bow Sac that I recommended in my previous post:
http://www.wakemakers.com/fly-high-open-bow-sac.html
With that you'll be able to fill the rear sacs up more for wakeboarding right off the bat.
If you don't have a filler cushion for the bow you'll have to make or buy one to support that bag sitting in the whole bow. You'll probably want a second pump too because it will take quite a while to fill a single 1,000 lb sac, let alone 3 of them.
Old 05-15-2014, 04:19 PM
weist1013's Avatar
weist1013 weist1013 is offline
Boat: 2001 230
Send a message via Skype™ to weist1013
thanks guys, its just money right??
Old 05-16-2014, 10:30 AM
dvsone79's Avatar
dvsone79 dvsone79 is offline
Boat: '99 205v
That's the spirit!
