Hi all,
I’ve done a bunch of searches and read most everything I can find on winterizing, fogging etc. But I have a few quick questions to clarify before I do this next weekend. I live in Northern Ontario so it gets real cold all winter and the boat will sit from now (this month) till June before it’s back in the water.
The motor is a 1996 LT1.
1) Fogging with the LT1 engine. Most of the posts seem to talk about shooting some fogging oil into a hole in the throttle plate, behind the flame arrestor? Is this the same with the LT1? Does anyone happen to have a picture of where this is on my LT1? I’m also planning on removing the spark plugs and spraying a little directly into the cylinders.
2) Draining the block. From what I have read it’s not recommend using RV anti-freeze on this motor due to the aluminum heads. If I remove the various hoses mentioned in posts and turn the motor over once or twice it sounds like I should be good. Also need to remove the petcocks on the block. Is there 4 per side?
Thanks in advance for your input
Nidus72
Nidus72
