Old 05-13-2021, 05:57 PM
williamsatown's Avatar
williamsatown williamsatown is offline
Boat: No
Steering Cable Nut/Seal
This nut has a seal on it, but was loose long enough to wear down the starting threads. It goes on the steering cable.
Any ideas on a part # or if it can be replaced?
1999 Maristar LTR
Old 05-14-2021, 10:02 AM
Boat: No
Evidently I have to replace the entire steering cable to get to this nut that attaches to the steering tube... Does anybody have a different experience? I havenít searched the forum yet, but how difficult of a repair is changing the cable? My local MC dealer said that it was a two-man job and would take four hours for them.
Old 05-14-2021, 10:11 AM
88 PS190 88 PS190 is offline
Its not really a seal IMO more of a grease wiper.
What I'd probably do is take that down to the hardware store and try it on bolts till you find the right size. Buy 1 bolt cut a slot in it with a dremel disc and then tap those threads back into the aluminum and pop her back on.
Old 05-14-2021, 10:19 AM
jpwhit jpwhit is offline
Boat: Four Winns RX 5.7L 1996(sold), Nautique 200 OB 2011(sold), Nautique 200 OB 2012 5.7L, Mastercraft X25 2014 6.2L, Mastercraft ProStar 2019 5.7L
Just get the right size tap and fix the threads. Should be a very simple fix.
Mastercraft ProStar 2019 5.7L - Current
Mastercraft X25 2014 6.2L - Current
Nautique 200 OB 2012 5.7L - Current
Old 05-14-2021, 10:39 AM
Haven't done your boat but what am I missing here - you already have the floor out and the rudder exposed - does that nut not slip over the end and thread on?
In re: people to do the job. I've done cables on 4 different boats alone using a rope. Its usually about a hour once the floor and seats are out and most of that hour is usually finding hidden zip ties that are holding the old one.
I suspect the 4 hours and 2 people is more about the weight of removing the hatches and seats than the actual job.
Old 05-14-2021, 10:52 AM
Boat: No
You are correct, I have everything pulled out for cleaning etc... itís about as much access as you can get.
You are also correct about that ďgrease wiperĒ nut. I removed the bolt from the rudder and slid it right off the cable post. I hadnít really considered it, but I guess I could also just make a flush cut of the first initial threads and shorten up that aluminum nut altogether to get to clean threads. Then I could try putting it back on that steering post.
I was hoping there was a replacement part, but that wouldíve been too easy. Maybe this should be my order of trying to fix this:
Plan
A- try to retap the nut
B-cut the nut flush to get to clean threads
C-replace the steering cable
Agree?
Old 05-15-2021, 10:21 PM
Boat: No
Update-
I think this is a 7/8Ē thread. I couldnít find anything at Fastenal, Lowes, or AutoZone. Since it was trashed I decided to cut it. I got it on. Itís obviously a little bit shorter. How tight should I make it and are there any issues here that Iím not considering? If no one can give me any, I will probably try to make it through the season with this steering cable.
2020
