  #91
Old 09-16-2018, 10:22 AM
cmarston cmarston is offline
Boat: Mastercraft, 220 CSX, 2008, 400 hp
Thx. I will try to find his thread. Do the surf tabs also allow you to use them as trim tabs like the Bennett automatic trim tabs? On the other hand, can u use the Bennett trim tabs for helping with the surf wave?
Old 09-17-2018, 09:38 AM
Wicker68's Avatar
Wicker68 Wicker68 is offline
Boat: '09 CSX220 SS
I installed the Wake Worx Super Surf'r on my 220. Here are the two threads I created:
http://www.mastercraft.com/teamtalk/...ight=wake+worx
I like them because they double as trim tabs with no speed restriction as to when they can be deployed and you can do both at the same time.
As far as surfing, you need a ton (or multiple tons) of weight to get it to push. I run only in saltwater and I fill close to 3500 lbs in fat sacs. It's tough making these direct drives surf. Here's some pics of Steel Lafferty's brother Bob surfing off Fort Lauderdale beach behind my boat.
Old 09-18-2018, 07:42 PM
Thanks! Looks good.
Old 10-04-2018, 05:42 PM
For the 220, does anyone know a place that you could order a cover that would go over the entire t-top or would I need to have it made by a local canvas shop?
Old 05-16-2019, 03:58 PM
Could someone point me to where you fill up the freshwater tank on the CSX 220 and where the tank is located?
Old 05-16-2019, 05:32 PM
Wicker68's Avatar
Boat: '09 CSX220 SS
There's multiple ways I've seen it installed on these boats. I've seen some of the closed cooled boats have two hose hookups on the transom. While my boat has one hookup with a valve lever under the rear port seat to switch between going to the freshwater tank and the heater exchanger. Regardless, some type of hose hookup on the transom will fill the freshwater tank which is about 16 gallons.
Old 05-17-2019, 01:50 PM
Okay, cool. Iíll check it out. Thanks for the info!
