Based off the second pic not sure a hydrhoist will work. It takes some depth to sink them. The sunstream might be the best option.
Floating Boat Lifts
Originally posted by jgraham37128 View PostBased off the second pic not sure a hydrhoist will work. It takes some depth to sink them. The sunstream might be the best option.
I have an airdock, our lake today is around 8' less than full pool on its way to 15' below. Where my dock is I have to move the boat to the trailer at 5' below, usually in September as they take the lake level down. This lift is perfect for me, takes up no additional room, no sinking it below the surface, it works great. If you have some protection, in a cove, it works great. I have no idea how it works if you get heavy rollers periodically but on their site they show it installed in situations that look rougher than mine.
As I watch more videos my concern with a Hydro Hoist is noise the compressor makes. I think it is going to drive the neighbours crazy as we boat a lot. I do not think there is a work around for thiss so might need to look more at the Sunstream Float lift which would make less noise.
Originally posted by John Johnson View PostThis is what I was thinking.
@mmskiboat - get my pm?The sea, once it casts it's spell, holds one in it's net of wonder forever - Jacques Cousteau
Originally posted by mmskiboat View PostThe second pic is missing the 2nd floating dock, this is the one that I'm going to build again to have a U-shape to hold the new boat. We have lots of depth out that far and is the reason we need to be out that far in the lake. In the spring it seems very far to be out but come fall makes sense.
2017 Mastercraft XT21- Black & Calypso Green Flake and Coolfeel interior
2018 Audi Q7 Technik Navarra Blue with S-Line, Black Optics, Luxury package, advanced driver assistance, Audi Sport 21" wheels, tow hitch
The Sunstream Floatlift only requires 12" plus the boat's draft of water to operator. I can tell you I run mine into our soft lake bed in late September / October and it works perfectly. The best part about this lift is the ability to walk completely around the boat and clean it after every use. I do all my maintenance on the lift. I've even removed and replaced the prop and prop shaft while the boat was on lift. I can't say enough great things about these lifts.2002, X30, L-18, Red Metal Flake (the possessed boat)
Originally posted by mmskiboat View PostAs I watch more videos my concern with a Hydro Hoist is noise the compressor makes. I think it is going to drive the neighbours crazy as we boat a lot. I do not think there is a work around for thiss so might need to look more at the Sunstream Float lift which would make less noise.
Our lake can very from 835 ft to 865 ft, so floating lifts are all we see at our lake. The higher end docks tend to have hyrohoist. I have not heard of the other brand mentioned here, but will look into it.
We are building a new dock with 4'ft wide fingers on each side of the boat. You will need a finger (or other supportive structure) on each side of the boat to support the lift.
Originally posted by kscrib View PostWe are building a new dock with 4'ft wide fingers on each side of the boat. You will need a finger (or other supportive structure) on each side of the boat to support the lift.
The Sunstream Float Lift setup while not as clean looking makes a lot of sense as you do not need to fill up and air down anything.
Our lake while not small is not that big either and noise travels, since we want to ski we will be using the boat early in the mornings. It is take 4-5 mins to fill on each docking that could add up to a lot of noise for our bay.
Originally posted by CottagerGreg View PostI would recommend if you have a floating dock to make your dock fingers wider if possible. I have a fibersteel lift FYI. I think I need to service the bushings as they are binding a bit.
The lifts with float tanks are really simple mechanically, in that the blower motor is relatively cheap and simple compared to the ones that use hydraulic rams to swing the flotation in and out from under the boat.
We have a maximum slip width of 11 feet (corp of engineer will only allow us to have a 19 ft wide dock at our location). So unfortunately the Sunstream is not an option for us as it needs a 14 ft slip.
I am following this thread in hopes of making sure I buy the right lift. Right now it looks like Hydohoist....
