Old 07-31-2016, 11:36 PM
Prostarski190's Avatar
Prostarski190 Prostarski190 is offline
Boat: 03 Prostar 197, 310 HP Predator w/ Powerslot
Originally Posted by kwoody51 View Post
Change out the oil and get a new coolant sensor. They are ~$17 from Napa. This is likely the part number MPE TS4052SB
Once you have a new sensor you can compare it to the old one for reistsnce or you can do it right in the store.
You won't know what to look for next until you confirm if it is or is not the ECT.
Does anyone have a photo of the ETC or where it's located? Thanks
Old 07-31-2016, 11:44 PM
kwoody51 kwoody51 is offline
Boat: '08 X14
It should be located on the starboard (drivers) side, on the middle of the engine, slightly below the exhaust manifold.
Looks like the part in the link https://www.napaonline.com/napa/en/p/MPETS4052SB/
Plug snaps off easy and 3/4" socket takes it out. It's a 5 min job...
Old 08-01-2016, 12:55 AM
Distributor cap is corroded and plug wires and plugs may need replacing. What's the best place to source these? Can I get them at Napa as well or should I get them from Skidim?
Old 08-01-2016, 09:44 AM
Boat: '08 X14
Napa will have those parts also.
Old 08-01-2016, 10:36 AM
Fletchx7's Avatar
Fletchx7 Fletchx7 is offline
Boat: 2002 Mastercraft X7
Prostarski, I'm interested to hear how this turns out. I am having a very similar issue. It started last weekend. I went out yesterday to try an replicate the issue. What I noticed is that fuel smell and the difficulty starting happened after the engine was up to temp. It was fine at launch and started right up after we had anchored for a few hours. Every time I stopped to pickup a skier, it take forever to start and then run very rough. My first thought was the distributor, but I didn't think about the sensor.
Keep us posted on what you find out. I'll dig into mine tonight and check the oil and distributor.
2002 X7 (Current)
1988 Tristar 190 Open Bow (Old)
Old 08-01-2016, 11:20 AM
when is the last time you changed those parts - ?
Old 08-01-2016, 11:36 AM
This is my 3rd season with the boat so I'm not sure when they were last replaced. Boat is at 800 hours and I've put around 100 hours on it.
Old 08-01-2016, 04:27 PM
Is this the temperature sensor? It's on the intake manifold the next thermostat housing?
Old 08-01-2016, 04:46 PM
Yes- that's it.
Old 08-02-2016, 03:30 PM
Yes- that's it.
Thank you, JimN
