Okay, the first casualty of the boat refurbish just happened. To a part I wasn't working on...
Disassembled a lot of the engine (just the bolt on parts like starter, alternator, valve covers, wiring harness, etc) a week or so ago without any issue. Left the oil in and didn't touch the oil filter or oil fill tube, just taped off the oil filter.
Past couple days spent cleaning and prepping and painting the engine block without any issue.
Till this morning, went out to bolt some parts back on and the entire oil pan had drained out into the bilge. No oil was anywhere on the block or out of the cap on the end of the oil drain hose.
Only thing I can figure is jostling around the oil drain hose in the bilge when I was moving plastic sheeting around underneath the engine bent the hose a bit too much and my guess is it drained out of the connection to the oil pan. Its so tight under there its the one thing I can't get to to really check yet.
So my question is how do I fix this? I assume I have to raise the engine block enough using the 4 large nuts where it attaches to the hull and replace it. And probably that means disconnecting the drive shaft as well. Is there a specific technique to do this right?
And is there a specific part # I should look for the oil drain hose? I haven't started searching for that yet.
