Old 09-05-2018, 08:37 PM
DVW70 DVW70 is offline
Boat: Mastecraft, 190, 1987, 351
1987 Prostar 190 prop shaft diameter?
Is it 1 or 1-1/8?
I have an opportunity for a 2003 prop 13.25x16 for use in a pinch but its 1-1/8 diameter
Old 09-05-2018, 08:48 PM
Originally Posted by DVW70 View Post
Is it 1 or 1-1/8?
Could be either size with no information.
Just look and see.
Several ways to tell from looking at the boat.
John 14:6
Old 09-05-2018, 08:51 PM
Thought it was simple so I’ll put a caliper on it
Old 09-05-2018, 09:02 PM
Look on the face of the hub of the prop. The prop size will be stamped on it, including the hole size diameter.
Look on the tag of the transmission for the standard or the gear reduction option (power slot):
1:1 gear ratio = 1" dia
1.52:1 gear ratio = 1-1/8" dia
John 14:6
Old 09-05-2018, 09:10 PM
Well that settles it I know for sure it’s 1:1 - thanks for the hep!! DVW
Old 09-06-2018, 09:57 AM
Strreamline Strreamline is offline
Boat: 1988 Mastercraft Platinum Prostar 190
They sell prop shaft adapters to bring a 1" shaft up to 1 1/8". Some will say sketchy, but for an emergency basis it may not be a bad idea if the prop is free.
Old 09-06-2018, 10:38 AM
88 PS190 88 PS190 is offline
Is it 1 or 1-1/8?
So lots of issies there 2003 is probably splined vs keyed. Your 87 regardless of transmission would be keyed shafting.
1" shaft is a 1:1 ratio 13" diameter by 13" pitch
1.125" shaft is a 1.5:1 ratio 14" diameter 18" pitch.
The way this works is that for every 1 turn of the engine a 1:1 boat wants to move forwards 13" in the water but slips a bit. A 1.5:1 boat turns the prop less rotation but due to having 18" of pitch it wants to move forwards 12" but slips.
That amount of slip is reduced on a 1.5:1 boat because the prop is larger and turning slower.
Between 1987 and today the 1.5 ratio was deemed too steep and most every modern ski boat has a 1.2-1.4:1 ratio with less than 18" pitch
That larger 13.25x16 prop even if it were a 1" tapered keyed bore would load the boat down being both larger so less slippage and 125% steeper pitch.
Hope that helps.
Old 09-10-2018, 06:45 PM
Thanks for the great info. I purchased a 13x11.5 three places new style CNC prop (everyone said you need a puller a a spare prop) - boat definitely more pop out of the hole and interesting the 4 blade 13x13 the engine would hit 4950 and 45mph at wot now 4600 and 44MPH - something’s off a little but I’m not barefoot in and we saved the weekend - all is good...
Old 09-10-2018, 11:00 PM
cbryan70's Avatar
cbryan70 cbryan70 is offline
Boat: 1993 Prostar 205
Your motor should not be hitting 5k....
Old 09-15-2018, 11:17 AM
The teach is original and I can confirm accuracy but the 4 blade 13x13 WOT would show 4950 and the new 13x11.5 3 blade is happy and running well at 4600 dunno why. And getting the 4 blade fixed and adding cup to it to bring down the rpm regardless.
