LT-1 molded hoses needed
Originally posted by WeekendsR4Me View PostBumping this thread to the top. Just bought a 98' Prostar 205 with the LT1, and would like to have the "holy grail" hoses on hand in the event I need to replace. Anyone have an extra set, or is there interest in having another batch made by the supplier in the earlier threads?
I was able to get a set from Bruce with Action Water Sports in Fenton Michigan.
He may still have some.
Worth a phone call. He was very helpful and shipped quickly.
They’re not cheap but don’t know if another option.
Not at all, $69. It does seem a little high but it beats not having them if you have a shut down issue after you've troubleshot other items. The big thing with the crank sensors is SAVE the BRACKET, because that is very expensive item even if you do find one.
I've got several spare items for the LT-1 and even have a full spare Code 5 push button ignition that came standard on this boat.1993 25th Anniversary Limited ProStar 190, #17
Think I’ll get a set if they’re descent quality.
Better to have them and not need them than to need them and not have them.
BTW, I got some original plug wires and a few odds and ends through Inboardonline.com.
Shipped straight from Indmar. Guy that helped me over the phone said they were owned by or affiliated with Indmar and could source lots of parts not listed on their website.
Shipping calculator has a glitch but don’t let it scare you away. Actual freight was much more reasonable.
Hey there LT-1 owners!
As you probably know there are 3 unique coolant hoses on this engine. The lowest hose is a 180 degree bend and not very expensive. The other 2 hoses have very unique bends and they also have different diameters on both ends! WTH?!
They continue to increase in price as time marches on... so I am pulling the trigger and getting mine now! They showed up today. I have them when I need em! If you are looking for these hoses too, give Bruce a call at Action Water Sports-Fenton MI 810-629-1342.
I am into these 3 hoses $232 plus S&H, they won't get less expensive ( =
I promise! Been watching prices for the last decade... finally decided that I should have them before my 98 S&S PS190 gets to 30 years old.
P.S. the rest of the hoses are simple to source from straight stock by using the inner diameter.Last edited by JLeuck64; 06-17-2020, 12:09 AM.http://www.mastercraft.com/photopost...er=2572&sort=1
Need LT-1 parts?
89058397 (pump outlet side)
