Old 09-11-2016, 10:42 AM
MeanV2 MeanV2 is offline
Boat: Searching
Changing Transmission Fluid?
Anyone ever try one of these for emptying the transmission fluid out?http://www.ebay.com/itm/130894427851...%3AMEBIDX%3AIT
Or is a hand pump better? Thanks!!
Dan
Old 09-12-2016, 08:49 AM
never used one... if you have a harbor freight close by you can get it there and if it doesn't work you can at least take it back...
Old 09-12-2016, 08:54 AM
04 Star Rider 04 Star Rider is offline
Boat: 2004 Mastercraft X-Star
Half that price at home depot.
http://www.homedepot.com/p/Everbilt-...3-HD/204667248
2004 X-Star
Old 09-12-2016, 10:21 AM
88 PS190 88 PS190 is offline
This is what I have/use.
https://www.amazon.com/Mityvac-7400-.../dp/B000JFJM14
I added a brass 90 degree ball valve to mine so that you can "charge" vacuum and then open it. It also reduces drips when getting into/out of the boat.
I had a small electric pump - but then you are discharging fluids into a different container, and I just found that very difficult to manage in a clean way inside our boats.
Old 09-13-2016, 01:46 PM
gt23's Avatar
gt23 gt23 is offline
Boat: 2015 X30, 2008 X15 (sold)
so what are guys doing that have 2011-2016 for tranny fluid
ATF or Rotella 15W40 motor oil; both are approved by Ilmor
thoughts on changing over to Rotella...
NOTICE: The specified oil for all Ilmor products equipped with a ZF
transmission is Rotella T 15w40 motor oil. For all legacy products (2011-
2016) that used Automatic Transmission Fluid (ATF), the ATF may be
changed over to Rotella T 15w40 motor oil during maintenance or when
winterization is performed. For all MY2017+ products, the transmissions
currently use Rotella T 15w40 motor oil. These products should continue
to use Rotella T 15w40 motor oil throughout the life of the transmission.
Failure to use the correct oil in the transmission can cause transmission
damage and/or void the warranty. For more information, please contact
your local authorized Ilmor dealer.
Old 09-14-2016, 03:04 PM
lentiman's Avatar
lentiman lentiman is offline
Boat: 2012 MasterCraft X2
I just changed the ATF out of my transmission in my 5.7L ILMOR. It was super easy and there was nothing in the filter. I used the Rotella 15-40 as recommended by ILMOR, purchased from Amazon. Had to disconnect and move wiring harnesses to get access but it was an easy job and overdue at nearly 350 hours.
Old 09-14-2016, 04:29 PM
gt23's Avatar
did you just suck it out of the dip stick, or open the filter and suck it from there; were there any lines to bleed? If so how did you do it?
Old 09-14-2016, 05:32 PM
gt23's Avatar
what i got back from Ilmor
When changing ATF to 15W40 oil this is what‘s required:
1-You have to suck all the transmission out by removing the dipstick and placing a suction tube inside the transmission.
2-You have to change the transmission filter.
3-Add 3 quarts +/- to fill.
4-15W40 Rotella is fine to use.
Old 09-14-2016, 05:44 PM
Endurance's Avatar
Endurance Endurance is offline
Boat: 1998 MasterCraft Maristar 200 VRS
Dan
I tried one like that and they suck . . . or don't suck as the case may be. I found it slow, messy, and too many moving parts to juggle. I'm as frugal as the next guy, but after a few duds, I decided to do it similar to 88 PS190 and buy a suction-type device. This is the one that I bought: https://www.amazon.com/America-5000-.../dp/B0000BYMZQ
My buddy has a vertical one like 88 PS190 mentioned and it actually works a little better than my MarinaPro. The reason I bought the MarinaPro is that it is horizontal and I need to fit it under my boat seat and have it not tip over.
You will thank yourself if you buy a decent suction oil changer. I made a 1/4" female swivel pipe thread adapter for mine and use it to change engine oil too. It works great for that.
Old 09-14-2016, 06:18 PM
uplander uplander is offline
Boat: MC 2002 X30
Mitivac will suck it out no problem, warm it up prior to the sucking
