Old 06-11-2009, 05:58 PM
dino dino is offline
Boat: Mastercraft, x-star, 2004, 350
I have tried it all on my ballast if someone could tell me something
I have taken my boat into the dealer, they replaced the impellers and one pump. I got it back and still problems. It filled, which was an improvement, but now they won't empty. Has anyone ever had anything stuck in the lines or anywhere else. The check valves are not cracked. My batteries are new. Please, I just want to fill and then empty my tanks.
Old 06-11-2009, 06:17 PM
RWB_XSTAR's Avatar
RWB_XSTAR RWB_XSTAR is offline
Boat: 2004 XSTAR
Sender unit for the fuel tank is a simple swap. Simply take the old one out and drop the new one in. I think it's only 6 or 8 bolts. Should take 5 to 10 min to do.
When I replaced mine it didn't work right away. I was told to fill the tank all the way full and that may help it register. Filled my tank and it's worked like a champ since.
Originally Posted by gobigorgohome View Post
good news....swapped in new batteries and bam! all 3 tanks are pumping water like champs! i guess the voltage was too low for the pumps to run properly, ill have to check out the sender unit issue as my gas gauge is off and on. Is the sender unit replacement pretty easy to do on your own?
Old 06-11-2009, 06:21 PM
RWB_XSTAR's Avatar
Boat: 2004 XSTAR
All the tanks won't empty? Not sure what is going on there. My KGB wouldn't empty awhile back. Problem ended up being one of the relays being bad (I think they are 25amp). Anyway...they are in the rear locker, remove the black cover on the ballast box.
Old 06-11-2009, 09:28 PM
Jerseydave's Avatar
TT Hero
Ballast sending units can be calibrated easily. Fill all three ballast tanks, adjust the "full" calibration screw at the top of each tank. Now empty all the ballast tanks and adjust the "empty" calibration screw at the top of each tank. I've done this a few times but they still don't always read correctly. I just watch the water empty out until it's done.
This weekend I'm changing one of my impellers to the new green impeller. Hope it's an improvement over the black or yellow ones.
I was njskier on here.
Old 06-12-2009, 09:46 PM
fbroen's Avatar
fbroen fbroen is offline
Boat: None
We run three green impellers and they are money. Pumps don't get stuck like with black ones, and do not siphen as with the yellow ones.
Old 06-30-2009, 11:27 PM
DJnGA's Avatar
DJnGA DJnGA is offline
Boat: mastercraft
anyone know where the calibration screws are for the ballast tanks?
Old 09-20-2018, 12:02 PM
xstarstar xstarstar is offline
Boat: 2004 X-STAR, 6.0
I know this is an old thread but also would like to know how to calibrate the ballast gauges.
Old 09-21-2018, 07:46 AM
DBUSH36's Avatar
DBUSH36 DBUSH36 is offline
Boat: 2004 X-Star, MCX
There were 2 brass colored set screws on the top of original sending units for our boat. I also have an 04 star. With tanks completely empty turn “empty set screw until The Gauge reads empty. By this I mean turn it until it reads above empty and back it down until it hits the empty line. Right is plus. Left is minus. Fill tanks and do the same process but for full. I have a just of mine a couple of times and this season when I adjusted the set screws all fell apart and wouldn’t turn. they actually kind of disintegrated due to corrosion I think. I ended up purchasing three new sending unit from Mastercraft parts depot and they are a re-designed unit with no set screws. they are also pre-calibrated!they were completely plug and play and my gauges are accurate. The reason our gauges fail so often is because the sending unit sale usually due to water intrusion at the set screws.
Old 09-21-2018, 09:29 AM
Wheelin98TJ's Avatar
Wheelin98TJ Wheelin98TJ is offline
Boat: 2005 XStar
Excellent, thanks for sharing this!
Old 09-21-2018, 10:58 AM
DBUSH36's Avatar
Forgot to stress you must start empty and adjust empty first then fill and adjust full range.
