Old 06-29-2018, 12:54 PM
ldelosreyes12 ldelosreyes12 is offline
Boat: 2005 X10 - MCX 5.7L
Dripless Shaft Seal?
Can anyone recognize if this is a dripless? It is leaking pretty bad.
Thanks!
Old 06-29-2018, 09:02 PM
blackhawk's Avatar
Boat: 2006 X15 350 MCX
Does it have a waterline running to it? If it does, it is dripless.
We defy the mafia!
Old 06-30-2018, 08:16 AM
Waterline
Well that was easy ��. No it does not, Thanks!
I am just confused because most have a nut to turn to loosen....
Old 06-30-2018, 09:02 AM
88 PS190 88 PS190 is offline
It is a dripless. OJ props makes it and can get you a seal. Call em up for replacement. Not sure if the versions with the hose last longer, maybe they'll suggest you add one.
Old 06-30-2018, 05:05 PM
Thanks!!
Old 07-01-2018, 12:39 PM
wetterthebetter's Avatar
wetterthebetter wetterthebetter is offline
Boat: 1980,1984, Stars and stripes,1971 AquaCraft Drag boat, 1991 American Skier
Location: northern Sierras between Lake Tahoe and Sacramento
Before you replace the shaft seal, check your prop shaft or excessive wear.
My shaft had to be replaced there was a uneven Groove where the seal rides on.
Old 07-01-2018, 01:21 PM
I appreciate the advice! I'll check it all out
Old 07-01-2018, 02:36 PM
Not correct. The early version of the OJ drippess did not have a water line going to it. The water was added because the seal would overheat if the boat had poor shaft alingment. If you had correct alingement it would work just fine. My 06 had one without a water line.
-Tim
Old 07-01-2018, 04:37 PM
Definitely makes sense. Thanks
Old 07-01-2018, 11:41 PM
Pretty sure you nailed it! The dripless also has a lot of wear and needs replaced.
Thanks, everyone!!
