  #101
Old 02-23-2018, 09:00 AM
Double D's Avatar
Double D Double D is offline
Boat: 2008 X14, w/ LY6 400HP w/ 1.22 Ratio Tran
Originally Posted by scooter205 View Post
A little teak cleaning tonight
Sent from my SM-G935P using Tapatalk
Yep!! Nice!!
2008 MasterCraft X14, LY6, 400 HP
1994 MasterCraft ProStar 205 (SOLD)
Old 03-28-2018, 09:45 PM
97prostar205 97prostar205 is offline
Boat: Matercraft 1997 Prostar 205
I have a 1997 205 with the same number of hours. It is a Great boat. If you don't buy it I might be interested. We have had 20 years of great times in our boat. Go for it.
Sent from my XT1080 using Tapatalk
Old 03-28-2018, 11:02 PM
Tony Webb's Avatar
Tony Webb Tony Webb is offline
Boat: 2018 Prostar
Send a message via AIM to Tony Webb
Originally Posted by waterlogged882 View Post
I have a few photos (actually a lot). Hopefully (S)cooter will not mind an innocent thread jack....thanks Cooter...
New after I got it:
  • 303 protectant gallon (Amazon)
  • 4 - Polk DB 651 cabin speakers (Sonic)
  • Blue Seas Isolator System with Perko switch
  • Boat Buckle tie downs for transom
  • new style pitot pickups (DIM)
  • Form fit water hose
  • Brass elbows for water hose to riser
  • Acme 541 prop
  • Impeller
  • Engine belts
  • Riser gaskets
  • Packing - dripless shaft packing
  • Registration numbers
  • battery box (2)
  • two Interstate batteries
  • battery cables_wiring (from genuinedealz.com)
  • Electrical Connectors_Sonic Electronx
  • Livewell plug (plug cooler compartment from outside of box; under floor)
  • Rockford amp
  • Pyle RCA Cables for Amp (2)
  • cable ties
  • Trailer Lights_eTrailer
  • Mirrors (DIM)
  • Shifter knob (DIM)
  • Fuel Sensor for tank (DIM)
  • Clean-check amplifier - Rockford Fosgate 400 watt (4x100)
  • Pebble texture Adhesive Black Vinyl Guard 9" wide Roll and 24"
  • 4 Flat Trailer Extension Male/Female Plug wire cord
  • Cable Ties and More_Shrink_Clamps_Wire Loom
  • Decals - Red Shadow set (BAWS)
  • fire extinguisher (2)
  • Teak Platform_First platform for 93 MC (Action Water Sports)
  • tires - Kuhmo (Tire Rack)
  • Head gasket set (DIM) - 175
  • GT40P heads (Tri-State Cylinder Head)
  • Head Install (Motor Head Kingston)
  • new hoses (water, exhaust) (DIM)
  • Impeller_Carb spacer plate_Spark plugs (DIM)
  • Clarion MC309 head unit (Sonic)
  • New upholstery (Viper)
  • New carpet (Viper)
  • wheels (from Team Talk - Morristown TN)
  • Perfect Pass Stargazer 3-event speed controller (Skier-to-Skier)
  • 105 amp upgraded alternator (DB Electrical)
  • Fuel line for PCM pump (DIM)
  • new raw water pump (Marine Parts Source)
  • Impeller/Seal/Gasket (DIM)
  • boat buddy, keel roller for trailer_etrailer
  • Boat buckle for bow eye (single)
  • stainless cupholders (2)
  • Epoxy 3M edge sealer for lettering
  • Teak wood for cupholders
  • Cell Phone-accessory holder
  • Bazooka RBCM-100 Bass remote controller (Sonic)
  • Bazooka MBTA8100_subwoofer (Sonic)
  • Aluminum Channel for seat riser (Grainger)
  • Polishing Cleaners/compound (Amazon / TCP)
  • Gas Lift Springs (3) engine cover/passenger back of seat
  • Polishing pads (Premium Boat Care)
  • Porter-Cable 7424XP Kit 6" Dual Action Polisher Kit
  • 3M Perfect II Extra Cut compound
  • 3M super duty compound (gallon)
  • Clarion MW1 Watertight Black Face with Stainless Steel Bezel Remote with LCD Display
  • Clarion MWRXCRET Marine Remote Extension Cable, 25 ft
  • PAC USBCBL 6-Feet USB Cable with Mounting Bracket
  • Heating pads for driver's seat
  • Grommets and Steering cable plate
  • Blower - Attwood - Baron USA
  • 12-Volt in-dash receptical
  • Kumho Tire - Tire Rack - Replacement $140_mount $10
  • Trailer Leaf Springs (2) - Northern Tool (installed Nov 2014)
  • Trailer Spring Parts - etrailer
  • Ignition switch (installed May 18, 2015)
  • Ladder for platform
  • Aluminum angle for cupholder - 4' stick - Grainger
  • Billet clamps for cupholders
  • Throttle cable brake
  • Steering wheel center piece - from TT memebr
  • Cover Sports boat Cover
  • XPC Dripless Shaft Seal Coupling (OJ Props)
  • Cutlass Bearing(OJ Props)
  • Audio Delay switch
  • Impeller
  • Exhaust Hose (Atlantic Boat Co. Amazon)
  • Grab Handle (6" - Iboat)
  • Third set of trailer wheels
  • Pertronix electronic ignition module
  • Flamethrower II coil
  • Carburetor refresh
  • Fuel filter canister kit (moved to rear where the battery was)
  • Engine cover sound deadener
I'm not much on posting "look at me" type stuff but since you ask...here are a few pictures. I took the entire boat apart and reassembled with the above...mostly all in one winter layup period. I have other costs not listed but this is the majority of the costs.
I was working away on this thing and finished it up for the coming season. One day I cleaned out my email and sorted mail that related to electronic transactions etc. So I decided to put the items in Excel (mistake for a hobby). It added up quickly. Never put your hobby in an Excel sheet.
Several large numbers from above: PerfectPass, skins, carpet, GT40P heads, two platforms, dual batteries......I also used (undocumented) a lot of stainless hardware from the local store and Graingers.
I moved the battery from the rear to the front (duals) so that required all new cable runs, etc.
I have recently rewired the boat with another $500 in material alone.
The engine is coming out this fall for a bottom up rebuild (upping the HP) that will run another estimated $5000 all-inclusive, and my labor for lifting, re-setting, and aligning is free to me...
The 190 Looks Better than new...Very Nice... what a cracker
2012 X7 Sold
2012 VTX Sold
Old 03-28-2018, 11:07 PM
Tony Webb's Avatar
Boat: 2018 Prostar
The 205 looks great, nice work on the teak...In 5 years time you will not even care how much you paid for it, boats are a great lifestyle choice ...not an investment.
2012 X7 Sold
2012 VTX Sold
Old 03-29-2018, 10:41 PM
scooter205's Avatar
scooter205 scooter205 is offline
Boat: 1992 Prostar 205 351HO
We are super pleased with it. Looking back, we could have paid more and still would have been happy. Great driving boat and it cleaned up really nice
Old 03-30-2018, 09:34 AM
Chuck, you ****ing hold out!!
-Tim
Old 03-30-2018, 11:34 AM
John 14:6
