Old 06-21-2020, 05:55 PM
jameslyle jameslyle is offline
Boat: 2006 X2
DIY piggyback setup
I have a couple 400# flight bags already, just curious if there are any DIY tips (or tutorials)for plumbing them into the back piggyback, or if it Justin works alot better to buy the kit from WakeMAKERS. I have a 06 X2 for reference.
Old 06-22-2020, 08:04 AM
bturner2's Avatar
bturner2 bturner2 is offline
Boat: 2016 200 Sport Nautique
There's no magic in their kits other than someone has already done all the homework for you and built out all the components. I just finished plumbing mine in with some used bags I picked up on this forum, a bunch of clear premium 1" tubing and a hand full (OK 2 hand fulls) of fittings and clamps from WakeMakers.
If you call WakeMakers they'll walk you though everything you need. On the fittings I did the more expensive quick release "anti oil can" fittings for the bags/lines so I can remove them when I want to clean and used the premium clear hoses. I also bought silicone fusion tape to wrap all the clamps so nothing would snag on them.
Couple tips from my install.....
Plan out your fill/vent hose runs before doing anything else. Get enough hose for the vent so you can create a loop in the line from the bag to the vent fitting on the side of the boat. I screwed this up on my first attempt and had an binding issue with the hose in the rear compartment and also a siphoning issue. I looped a 5' section of hose that was probably a foot away from the vent fitting and all my problems went away.
What ever you think you'll need in hose you'll probably need twice as much. I thought I was going to have all kinds of extra tubing when I bought the 10' for the vent lines and it ended up being perfect with 5' on each side.
You have a choice of straight or 90 degree quick disconnect fittings. If you're not 100% sure want you need, buy both so you can get the job done in one effort.
Like I stated before this isn't a hard thing to do but if you don't know what you need you'll either end up buying not enough of something (most likely) or buying too much, which IMO is always better as I'd rather get the job done in one effort.
Old 07-06-2020, 01:04 PM
leebo556 leebo556 is offline
Boat: 2016 X30. 6.0 ~4500lbs of H20 500lbs of Pb
James, did you have any luck with your additional bags? I tried to piggyback some 400s off of an IBS bag in the nose and the 400s fill fine, but will not empty. Still trying to figure out a good way to manage this. Wave is awesome though...
Old 04-13-2021, 03:01 AM
Richy Richy is offline
Boat: 2010 x30 ss
Hi,
Do you think these two configurations can work?
or
Old 04-13-2021, 08:20 AM
Boat: 2015 X30, 6.2L
2nd one will work as long as thatís a spring loaded check valve on the vent line.
Old 04-13-2021, 10:50 AM
jpwhit jpwhit is offline
Boat: Four Winns RX 5.7L 1996(sold), Nautique 200 OB 2011(sold), Nautique 200 OB 2012 5.7L, Mastercraft X25 2014 6.2L, Mastercraft ProStar 2019 5.7L
With the first configuration, you'll run the risk of cracking your factory ballast hard tank if the piggyback bag is in the locker above the hard tank. The floor above the hard tank is not strong enough to support the piggyback bag by itself. The hard tank must always be full of water when there is any weight on the floor above it. That has to hold true during fill and drain.
Mastercraft ProStar 2019 5.7L - Current
Mastercraft X25 2014 6.2L - Current
Nautique 200 OB 2012 5.7L - Current
Old 04-16-2021, 02:03 AM
Boat: 2010 x30 ss
Okay, thank you, Iíll keep the first solution.
I found fatsac suitable for the X10/ X30 but I donít know what ordered for the front. I have 3 choices, Sumo Max Open Bow Ballast 500 or 750lbs?
Or fatsac W711 725 lbs?
Thank you for your advice
2020
