Originally posted by Thrall
View Post
F150 and X-Star?
Boats are actually relatively safer to tow than an RV. Other than the vastly different profile, boat trailers have the axles near the back of the trailer due to boats having a lot of weight at the rear. The relatively longer wheelbase lends itself to stability.
When manufacturers (really, the lawyers) make ratings, they have to use the worst case scenario, which is usually a high profile RV. Law enforcement of tow ratings is variable, but insurance in the case of an accident is most definitely not.
I used to tow my 08 Chaparral 276 with a F150. Definitely need a WDH to achieve max towing capacity. That being said I only towed it 4 times a year. If I was towing it more I would have went with a F250. Launching a 28' boat is not something you wanted to do frequently. I did have to drive cautiously maintaining a good stopping distance.
Originally posted by jbmccul View PostSouthwest Misery sounds like a rough place to be, but in all seriousness that max tow is rated at 13,000 pounds. With all of the additional upgrades that come with it you shouldn't need another truck for the XStar. Though most people on the forum think you need a 3/4 ton to tow anything larger than a canoe.
+1 for keeping the F150 and towing with that on the regular. You're well within the truck's capabilities, weight-wise, so if you go slow up some hills who cares?Tim
Ohio State Engineering - Go Bucks
1998 MC MariStar 225VRS
1995 MC ProStar 205
Originally posted by Tsumi View PostThe monkey wrench is that if you are ever in an accident and insurance finds out that your truck wasn't properly set up per manufacturer guidelines, there is a very high chance any claim you have will be denied.Aric
LONE STAR MASTERBASH 2022
Register Here
2019 XT22 - Ear Bleeder
2022 Sea Hunt BX22 CC
For Sale:
2020 Crest 240 SLC Tri Toon
Originally posted by MC25 View PostSupremely doubt that would happen in this scenarioOriginally posted by cmasty View PostIf this logic is true, any mc owner with a newer boat (except for pro stars) are out of legal compliance unless they are in a 3/4 ton or larger tow vehicle. Every single boat is over 5000lbs with a tandem trailer. Hell, even the pro stars are within 3-400 lbs of 5000 on a tandem trailer, and this is assuming no fuel and no gear.
https://www.mastercraft.com/media/km...nal_2021my.pdf
Originally posted by Thrall View Post
Wanna tow like a baller, rip up every steep grade at 80mph, put minimal wear n tear on your truck, etc? Get the baddest diesel your wallet can handle and make sure it has the platinum long horn Denali package too while your at it.
I’m that guy. My personal truck is and has been a tuned diesel for many years. And I tow a X2 and a 7klb snowmobile trailer. Why? Because I can afford to have the luxury of a truck that is more than necessary.
But over many years, I’ve towed and still do, almost interchangeably with everything from 1/2 tons to class 5 trucks. Guess I don’t think much about it.
Originally posted by Tsumi View PostIt's what everyone on the internet says will be the case when towing over your weight ratings, if the insurance finds that it can be in any way a factor in causing the accident (obviously someone running into your trailer wouldn't count). Whether or not it's true, I'm not entirely sure.
Originally posted by curver900 View Postthis is an internet myth... your insurance company will pay for an accident when you are driving intoxicated... and will pay if you are over some manufacturer guideline... all day long every day... and twice on sunday... the manufacture guidelines are just that guidelines.. they are not law...
Originally posted by j.mo View PostIt’s rarely ever the max tow capacity, and nearly always the PAYLOAD capacity.
I’d say the majority of these wake ships are out of the payload capacity of half ton trucks.
A weight distribution hitch actually moves about 10-20% of the tongue weight onto the trailer axle, depending on setup. If you take your truck onto a scale with a weight distribution hitch, you will find that overall truck weight is lower and trailer weight is higher than without a weight distribution hitch. Theoretically this does increase your payload.
