Old 06-11-2019, 06:38 PM
Jwa08x1 Jwa08x1 is offline
Boat: 2008 Mastercraft X1
Do you have any of these left for purchase?
Old 07-09-2019, 09:24 PM
Dsimms Dsimms is offline
Boat: 2007 mastercraft x45
Sent PM, I need 2 pins
Old 07-15-2019, 04:03 PM
Redwhiteblue x-14v Redwhiteblue x-14v is offline
Boat: 2010 Mastercraft x-14v 350/350hp
Are these still available? Mine just broke last week. I still have a handle to mount it to. I would be willing to buy 2 in case the other one breaks. Deciding if I need to go buy the $130 assembly this week.
Old 07-23-2019, 06:04 PM
StrmChzr StrmChzr is offline
Boat: 2005 XStar
Need 2 myself! Sent pm
Old 07-24-2019, 12:08 PM
NoSubstitute's Avatar
NoSubstitute NoSubstitute is offline
Boat: 2008 Mastercraft X-2
Originally Posted by trunderw View Post
Can anyone explain how to screw the handle back in without ruining it? I can thread about a half inch then the handle spins and the only way I can see is to use pliers on the big threads to screw it into the tower. Do I take it apart or what?
Can anyone answer this? I got my new pin, and am only able to get it finger tight. Once that pin is in, I can't figure out how to thread the main threads into the bracket. I can only get it about half-way, and the pin doesn't even stick out past the edge. I really don't want to grab on to it with vice grips to screw it in the rest of the way. How do you install it?
Current: 2008 X-2 SS
Previous: 2003 X-10
Old 07-24-2019, 12:35 PM
07OrangeX2 07OrangeX2 is offline
Boat: Mastercraft X2 2007
if your talking about the large thread housing, use a rag and some pliers together so you don't ruin the threads.
I'm really surprised its that hard to get back in, did you have a tough time getting it out? are the threads already dinged up causing an issue?
Old 07-24-2019, 12:38 PM
Also- is the pin threaded enough on the T handle? Its easier to get the Handle and pin together if its on the tower. (assuming its all assembled on the tower) Set the pin in one of the holes and put pressure on the rack like your going to rotate it around. That pressure will prevent the pin from spinning and it will allow you to thread the handle onto the pin.
PM me if you looking for some pins. Running another batch here very soon!
Old 07-24-2019, 12:40 PM
More Pins on the way
All,
just a quick FYI- in the process of making more soon, I will let you know when I get them!
Thanks
Old 07-24-2019, 12:41 PM
Yes, I did have a hard time getting it out. I had to use vice grips as I think it had oxidized together. The little allen screw was stripped, so I couldn't back that out at all. The threads are okay. I'll try the rag and pliers, but I'm concerned if I can't get it screwed all the way in, I'll be stuck with the pin not doing anything.
Previous: 2003 X-10
