2005 Mastercraft X-30. It's always been this way. Just figured out the actual speed measurements today using a cycling app to record actual speed. So when the speedometer says 33 mph, it's actually 22 mpg. When it shows 16 mph it's actuall 11 mph, etc. etc. It doesn't change it's locked into this 1.5 to 1 mph measurement. Any idea of what the issue is?
Speedometer showing 1.5 mph for every actual 1 mph.
Originally posted by masterdaft View Post2005 Mastercraft X-30. It's always been this way. Just figured out the actual speed measurements today using a cycling app to record actual speed. So when the speedometer says 33 mph, it's actually 22 mpg. When it shows 16 mph it's actuall 11 mph, etc. etc. It doesn't change it's locked into this 1.5 to 1 mph measurement. Any idea of what the issue is?
Sent from my SM-G965U using Tapatalk
Originally posted by Tom_S View PostFollowing is mine is a bit off as well. From my understanding though we both have the paddle wheel, perfect pass, without stargazer and I also have a toggle switch on the left hand side of my steering wheel labeled speedometer but I've never messed with that.
I will say that I upgraded to stargazer a couple years ago, and it is a fantastic upgrade that is worth the cost.
Originally posted by toddvdh View PostAll you do is push it, and it changes it + or - a little from the current reading. It should be pretty easy to adjust as you are moving, using a gps speed app to find true speed. I did it on mine and it was simple.
I did the StarGazer upgrade to my last boat and it was a great upgrade, I'd highly recommend it. I just did the Nautic Logic upgrade to my current boat and it works very well. That said I didn't have PP in this boat or I would have gone that route.
Originally posted by Tom_S View PostInteresting, I'll have to give it an actual test next time I'm out on the water. Speaking of upgrading, I was just looking at the naughty logic upgrade for my paddle wheel. Do you notice the loss of surging (if heavily weighted for surfing) after you upgraded?
To be fair, I didn't have perfect pass in my boat before I installed Stargazer, but I would notice the speedo jumping every once in a while when trying to hold a speed manually. So I'm not sure if naughty logic would help.
I tried going back and adjusting the speed to be wrong again thinking that would readjust the RPM to be correct so the cruise control would work again. But it did not. Any ideas? Assuming some sensor is off in the cruise control system.
The older versions of PP have a speedo adjustment setting, try in wakeboard or whatever mode pressing menu till it says speedo adjust then arrow key up or down to bring them together ie if the speedo is saying 18 and the boat is going 12 you have to arrow up till the boat is going 18 and saying 18
I think, based on his comments, he has the Mastercraft cruise system, not PerfectPass.
It is odd to me that your cruise system would be affected by the speedo adjustment switches. If you re-adjust back to the previous 1.5 mph indicated for every 1 mph actual, does the cruise system start working again?
—Sky------------------------------------------------
2006 X-1 Pumpkin Orange SOLD
2013 X25 Black, Green & Orange
